4bangerJP.com
May 19, 2012, 12:17:38 PM *
News: Welcome to 4BangerJP.com...                                         New Members check in at the, "Introduce yourself" thread...
   Home   Help Login Register
Pages: 1 ... 3 4 [5]   Go Down
  Print
Author Topic: ELECTRIC FAN or NOT ?  (Read 1565 times)
dwtaylorpdx
Member
Offline Offline
« Reply #60 on: November 25, 2011, 01:54:15 AM »
Well, depends on RPM , on a race engine turning 7500 you dont run a .065 gap, you run like .030.
The spark duration is longer with a narrow than a wide gap "usually"
Logged
94 YJ - 2.5 Hesco Cam B&B Ported - AX5 Trans w/Centerforce Dual Friction Clutch - 4" Rough Country Lift W/Black Diamond Shocks - D44 Rear w/ARB - D30 Front W/ARB - Homebuild on board electric air - Warn M8000 in Custom Bumper - Reunell Rear Bumper - Tuffy Console & Cargo - 265x85-16 Tires - 2M Radio
quicksand
Member
Offline Offline
JEEP POWER
« Reply #61 on: November 25, 2011, 01:25:28 PM »
Thanks good info to know, that might explain a few things and changes I feel. Thank you sir. Hope you had a good thanksgiving.
Logged
Nicks92jeeper
Member
Offline Offline
« Reply #62 on: November 26, 2011, 11:43:05 PM »
I found in the facts section for the screamin demon coil that it is beasured at 50,000 volts. I publishe the link in my spark plug gap thread.
Logged
quicksand
Member
Offline Offline
JEEP POWER
« Reply #63 on: November 27, 2011, 09:55:57 PM »
Wow 50,000 volts, I want one sounds good to me. I will look for that section, Thanks
Logged
jfrabat
Gargantuan Mango Tree Mechanic®
Member
Offline Offline
Finally USING the Jeep!
« Reply #64 on: November 27, 2011, 09:57:55 PM »
Call it bad luck, bt my Jeep runs better with the OEM coils than these ones.  I think its because of the impedance, but not sure...
Logged
grumpygy
Member
Offline Offline
« Reply #65 on: November 27, 2011, 10:11:55 PM »
I had an accel on mine and went back to stock.  You could smell something Electrical Burning. and it would start misfiring.  Put the stock one back on and its ran great.
  I wanted the kit because of the better Distributor cap that it has.  As all I've found are the cheap ones with the Aluminum contacts on the inside.
Logged
quicksand
Member
Offline Offline
JEEP POWER
« Reply #66 on: November 27, 2011, 10:22:44 PM »
Huh I have been running my accel coil for the last 7 years with no problem. Its amazing how some things work great for some and crappy for others.
Logged
dwtaylorpdx
Member
Offline Offline
« Reply #67 on: November 28, 2011, 12:13:34 AM »
I tore apart a Accell "Super Coil" a few years ago, it had a Echlin standard coil inside...
Cheers
Logged
quicksand
Member
Offline Offline
JEEP POWER
« Reply #68 on: November 28, 2011, 12:19:03 PM »
What are you serious, OK what do you believe is the best coil for a TJ ?
Logged
Pages: 1 ... 3 4 [5]   Go Up
  Print
Jump to:
SMF Theme © Gaia
Valid XHTML 1.0! Valid CSS!
