4bangerJP.com
May 22, 2012, 12:20:28 AM *
News: Don't feed the Trolls
   Home   Help Login Register
Pages: [1]   Go Down
  Print
Author Topic: Hand throttle  (Read 157 times)
chrisfranklin
4BangerJP.com® Donator
Member
Online Online
« on: December 28, 2011, 09:40:59 AM »
For you guys using hand throttles mounted on your manual stick/auto do you have any problems with the engine rpm when shifting gears?
Guess you'd just leave enough cable to accomodate gear change motion, right?
« Last Edit: December 28, 2011, 09:46:59 AM by chrisfranklin » Logged
'94 2.5 YJ S 5spd, Borla Cat-Back, CarSound Cat, Ceram. Headers, PDI Ignition, 62mm TB, Airraid intake, 19lb injectors, Sharp's Adjust. FPR, MeanGreen Starter, 210 amp alternator, D30 Aussie, 31" Destination MTs, bunch of armor.
FourbangerYJ
Servicing Squirrels Since 1995®
Member
Offline Offline
« Reply #1 on: December 28, 2011, 10:59:00 AM »
Just make sure your route the cable with enough slack and you will be fine.
Logged
Using tools you have not used in a while is like shaking hands with old friends. nod
jfrabat
Gargantuan Mango Tree Mechanic®
Member
Offline Offline
Finally USING the Jeep!
« Reply #2 on: January 03, 2012, 08:52:17 AM »
I have no problems with mine, and I run a hand throttle AND a cruise control...
Logged
Pages: [1]   Go Up
  Print
Jump to:
SMF Theme © Gaia
Valid XHTML 1.0! Valid CSS!
