4bangerJP.com
May 22, 2012, 12:42:45 AM *
News: Did You read the FAQ?        ...most likely not...        ...why not try it?
   Home   Help Login Register
Pages: [1]   Go Down
  Print
Author Topic: throttle body spacer need your help picking one out.  (Read 275 times)
AGUHR
Member
Offline Offline
WWW
« on: January 18, 2012, 08:40:46 PM »
I am clueless which throttle body spacer is good and was is great - so I am asking for your help.
Is this one ok?
http://www.ebay.com/itm/91-06-Jeep-Wrangler-Throttle-Body-Spacer-4-0-2-5-/300619815835?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AJeep&vxp=mtr&hash=item45fe565b9b
Can you recommend one specific one? I cant see anything different between the $85 and the $39 versions.
any help would be great.
Logged
94YJ SOA lift, 1" BL, 35 12.50 Goodyear kevlars, Aussie locker in front, 8.8 rear lsd. 4.10 gears.
sharpxmen
Chief Squirrel BlowerŪ
Member
Offline Offline
« Reply #1 on: January 18, 2012, 08:48:45 PM »
i recommend a smooth one.
Logged
AGUHR
Member
Offline Offline
WWW
« Reply #2 on: January 19, 2012, 06:35:20 AM »
Besides the helix or smooth is there a difference? I've read all the threads on here and it seems these are ok.
I simply dont want to buy something that is complete junk.
Logged
sharpxmen
Member
Offline Offline
« Reply #3 on: January 19, 2012, 09:18:55 AM »
there's not much to it as long as the holes are centered (matching the t/b) but that's hard to get wrong. the one you listed has the spacers and bolts and that's good, you don't really need the spacers with the manual transmission but they do help with the angle at which the cable pulls the throttle (gives you a bit more control going from idle to slightly open). the helix is more marketing than anything else
Logged
AGUHR
Member
Offline Offline
WWW
« Reply #4 on: January 19, 2012, 09:36:20 AM »
cool - I purchased it.  thanks for the explanation.
Logged
Pages: [1]   Go Up
  Print
Jump to:
SMF Theme © Gaia
Valid XHTML 1.0! Valid CSS!
