4bangerJP.com
May 22, 2012, 07:08:18 PM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News: New Smiley and Message Icons!
   Home   Help Login Register
Pages: [1] 2   Go Down
  Print
Author Topic: Blue Jeep  (Read 1798 times)
6099
Guest
« on: January 12, 2007, 09:42:00 AM »
Logged
SKI BOY
Member
Offline Offline
« Reply #1 on: January 12, 2007, 09:50:30 AM »
So did you take the 'Blue' beast across that DOT engineered bridge!!
Looks shakey!!
Logged
Ski Boy
6099
Guest
« Reply #2 on: January 12, 2007, 10:06:07 AM »
Didn;t have a choice. It was the bridge or 2 feet mud pit.
Logged
dexetr30
4BangerJP.comŽ Donator
Member
Offline Offline
Aloha Mr. Hand!
« Reply #3 on: January 12, 2007, 01:21:56 PM »
Looks like a lot of fun. I've never had the chance to drive over such a bridge situation.
Logged
lanulos89
Member
Offline Offline
« Reply #4 on: January 12, 2007, 01:22:04 PM »
so did u need new underwear after u crossed, that looks a bit hairy...
Logged
Steve-
new rig- 1997 tj 5spd, 1 3/4" spacers  front discos cutoms led tails, rear clicky locker, diff guards, and other various do hickies
old rig-1995.5 yj, auto,4.10's,  4" lift, 1" body 33" bfg muds, full pacesetter xhaust,  CAI, lots of lights no sway and track bars rear clicky locker led ta
SMC4WD
Guest
« Reply #5 on: January 12, 2007, 05:36:51 PM »
Quote from: "6099"
The second picture looks like you went through the 2 foot mud pit anyways...   lol
Logged
6099
Guest
« Reply #6 on: January 14, 2007, 08:26:52 PM »
Quote from: "lanulos89"
Wasn't wearing underwear  :evil:
Humid jungle + underwear +12 hour bumpy drives = ouch.
Logged
Jeffy
#1 FanŽ
Member
Offline Offline
« Reply #7 on: January 14, 2007, 08:37:09 PM »
Reminds me of South America.  I know a guy in Venezuela and his picts look similar to that.
Logged
Youtube Channel: http://www.youtube.com/user/4bangerjp
"If the motor car were invented today, there is absolutely no way that any government in the world would let normal members of the public drive one." -Jeremy Clarkson
SKI BOY
Member
Offline Offline
« Reply #8 on: January 15, 2007, 05:32:15 AM »
:shock:
that's more information than we needed 6099!!
Logged
Ski Boy
6099
Guest
« Reply #9 on: January 16, 2007, 06:03:19 AM »
Quote from: "Jeffy"
Yes pics are from somewhere near the equator in one of the world's oldest (and most logged) rainforests.
More pics.
The mandatory flexshot. 8 bolt rims are a pain to open.
It gets to about the headlights a couple feet up.
automatic 5"lift with stock YJ springs :twisted:  :twisted:
Logged
jagular7
Member
Offline Offline
« Reply #10 on: January 16, 2007, 06:57:05 AM »
Quote from: "6099"
Gotta love those Volvo axles? Want to ship a few over here to the US? Still turning drum brakes? With all the milky mud, how often do you perform maintenance on the axle, driveline, etc.? And the real question, where are the pics of the girls with the tone skin?Huh??
On that articulating picture, watch out for those brake lines. It looks rather tight. For worldly location, in the south Pacific islands?
Looks rather good for only having an axle swap.
Logged
Jeffy
#1 FanŽ
Member
Offline Offline
« Reply #11 on: January 16, 2007, 12:01:29 PM »
Oh, those axles are HOT!  Lots of ground clearance too! Not to mention close to half the weight of a D60.  Only problem for those of us in the states is parts availability.
BTW: if you have your brake hardline go behind the frame, it will give you more length.
Logged
6099
Guest
« Reply #12 on: January 16, 2007, 07:23:47 PM »
If you're serious about the axles, I could look it up for you.
I think they make a lot of sense. I should have just did the volvo axle mod and be done with it. No.... I had to do the SYE, 2.5OME springs, then 3.5 BDS, Ford 8.8 bla bla bla before trading all of that for volvos :roll:
Yeah, still turning drum brakes. Will be sending it in for discs this weekend. Drum brakes are *&%$# scary! Even after sealing them up with a fan belt mod. And I had to clean out like a pound of crud from each corner after every trail ride. No to mention I'd have to wire brush the drums, readjust the brakes....
Maintenance, just oil changes so far. It has new CV boots (front) so don't expect that going anytime soon. Other than that, it's just greasing kingpins.
Yeah , the articulation pic, relocated the brake lines already. thanks.
The girls? Ugh, girls who go like to go offroad here are pretty much the like men.  Don't bother. :D
Logged
6099
Guest
« Reply #13 on: January 16, 2007, 07:33:58 PM »
Quote from: "Jeffy"
Hey Jeffy, yeah, parts. Am even having trouble here. They're available but expensive. Frankly, these axles are very well made and very strong. The comp guys here run 2JZ twin turbos/7M/15BT etc behind them with 36" tyres (ok puny by your standards but that's the biggest we got) no problem.
Yes, you'd be surprised to know for the same strength as D60s they have the same diametre axleshaft as the Dana 30. Same spline count of 27 too. Measured them with some spare 30 shafts lying around. :shock:
Yeah, rerouted the brake lines. Thanks.
Picking up the babies:
Portal guts:
Drop box with CV boot:
3rd member:
Logged
Jeffy
#1 FanŽ
Member
Offline Offline
« Reply #14 on: January 16, 2007, 09:12:45 PM »
Those would be nice axles to have huge amounts of lift without having to change the suspension or any added weight.  It seems out here most like Mog axles.  I've heard of some people breaking the portal gears in them under heavy use.  I really like the Volvo's though.  I'd even consider buying one for a camping/crawling vehicle.  Although with a top speed of 65mph, they are a bit slow for our interstate highway system.
I really like the wide axles with negative offset wheels.  I've seen it done with full size D60's and Corporate 14 bolts.  Then they use HMMWV wheels to keep the tires under the body.  Yours looks really nice and skinny, sitting under the stock flares, too!  It looks like you've got over 15" of clearance under them.  What size tires are those?  Interesting to see that your Jeep had front fender mounted turn signals (holes in front fenders).  I thought those were only available for Europe?  They required them in Bolivia?
Logged
Pages: [1] 2   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
SMF Theme © Gaia
Valid XHTML 1.0! Valid CSS!
