http://en.wikipedia.org/wiki/Volvo_C303Hey, 6099, I saw your post on the Real4x4 forum. I didn't realize that you flipped your axle, that's too cool. With the 3rd member and rotating the ends, it make it easy, huh?
From what I've been reading the C303 axles are good for up to 37" tires. They aren't as beefy as the Mog 404's.
I take it the only downside is that vacuum line for the locker being on the bottom?
WEll, overall ,it's easy in theory. But it's still a fair bit of figuring things out.
The vacuum housing has been relocated to the top of the axle along with thedog gear arm.
I don't think you could run them upside down since diff oil will flood the bottom (now top) part of the vacuum diaphragm housing and make it much much slower for the vacuum to pull and release the diaphragm since it's displacing thick oil instead of air.
The caster angle's sorted but it puts the pinion at the wrong angle. So the only thing I'm thinking about is to re-drill the portal flanges bolt holes to clock the pinion up a bit. But I've had enough headaches fitting them in and will leave that for another year. :(
Yeah, i read that the 37-38inch territory is about the limit. But we can only get 36" tyres here. :evil:
Guardian 7,
As for axle wrap, no problem with the asthmatic 4 banger. But I left the original control arm bracket in place, just in case.
All volvos come with leaf springs
Mog 404 axles are much much beefier, agreed. But it's musch heavier and way too wide. I'd probably need like a foot wide fender flare. Not to mention I won't fit on the tight trails and logs brigdes.
Mog vs volvo
If any of you can get hold of volvos axles I'd strongly recommend it.
5" instant lift from portal drop boxes without penalty of funky driveline angles since you're at stock driveline height by re-using stock YJ springs.
No need SYE.
Low ratio. 6:1 or 7.1:1
With a 7.1:1 diff, crawl ratio works out a little higher than the rubicon's with a 4:1 case.
60"wide.
1 inch diametre tierods BEEEFY.
Disc brakes retrofitability.
Flip-ablility to fit driver side t-case output.
FR/RR locker, easily plumbed into your brake vacuum lines to work. Or you can conver to cable actuation similar to OX's.
Huge 3 inch diametre square axle tube.
Max torque only at the wheels due to portal design, so u don't need beefy driveline components, in other words, keep your stock 1310 joints etc...!!
1 ton rating, as strong if not stronger than D60s.
