4bangerJP.com
May 22, 2012, 07:12:52 PM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News: You didn't read the FAQ did you?                                      ...Why not check it out?
   Home   Help Login Register
Pages: [1] 2 3 ... 6   Go Down
  Print
Author Topic: 1986 CJ10A  (Read 4911 times)
jagular7
Member
Offline Offline
« on: February 03, 2007, 10:39:20 AM »
Something I just won at auction - $1200
1986 CJ10A, 14,636 miles, 5344 hours, diesel, auto, ps, pb.  No air compressor, no hydraulic pump, straight front axle (non-drive), 4 pintles, sliding rear window, fiberglass top, non-running.
More pics: http://s33.photobucket.com/albums/d99/jagular7/CJ10A/
Now gotta figure out how to get it home and check out why its not running.
From what I've found out in the past on these things: Nissan diesel, 727 auto, 208 with case linkage in 4x4low and chain missing (no linkage in cab), D70 rear (really wide), 4.88's, locker.
Logged
Jeffy
#1 FanŽ
Member
Offline Offline
« Reply #1 on: February 03, 2007, 11:44:10 AM »
That will be cool if you're able to convert it and make it road worthy.
Logged
Youtube Channel: http://www.youtube.com/user/4bangerjp
"If the motor car were invented today, there is absolutely no way that any government in the world would let normal members of the public drive one." -Jeremy Clarkson
Midwest MudslingerŽ
Member
Offline Offline
I need a bigger hammer!
WWW
« Reply #2 on: February 03, 2007, 12:24:09 PM »
That would make an awesome tow rig!
Logged
Liljeepz
Member
Offline Offline
« Reply #3 on: February 03, 2007, 12:26:14 PM »
Quote from: "Jesse-James"
X2 on that one!!! Cool
Logged
chardrc
Member
Online Online
« Reply #4 on: February 03, 2007, 01:51:40 PM »
personally i have mixed feeling s on this vehicle.. its would be a kick ass tow vehicle.  but it doesn't look like a jeep other than the inside adn the fenders tell the front... would be sweet to mock up a more traditional jeep grill on it... defiantly looks tough..
Logged
1990 YJ 4cly, ax5, 2.5 inch BDS lift, 31 MTr's,  Powertrax-lockers all around, track-bars removed, boomerang shackles, warn m8000 winch, electric fan.
Jeffy
#1 FanŽ
Member
Offline Offline
« Reply #5 on: February 03, 2007, 02:40:27 PM »
Why does everyone want to use it as a tow rig?  The stock wheelbase is really too short.  Top speed is something like 45-50mph.  To get the high pulling capacity, they have a NP208 transfer case that is locked into 4Lo with no front axle.  It will need a lot of custom work to get it turned into a 4wd Jeep.  Stretch the rear out a bit and put a chopped short bed on it...
Logged
jagular7
Member
Offline Offline
« Reply #6 on: February 03, 2007, 04:42:40 PM »
Wow, lots of interest, eh?
First in the plan is to explain to my wife the expense charge on the cc. That's the first hurdle. Next, get it home then figure out its overall condition.
Initial thoughts were to configure 4wd with matching axles, add wheelbase, reconfigure suspension, and add rear bed (flat or conventional). The D70 rear axle is 'WIDE' at 75", so most just rid of it as its easier/cheaper to add matching diffs. Found the cab is CJ based so CJ/YJ grilles/hood will work. Don't know about the windshield frame or hard doors. Cab top and actual tub (rear cab) are different than CJs. The frame is suppose to be similar to the J-trucks design which means the rear hangers are adjustable and outside the frame, thus reconfiguration of the suspension. I'll know more once I get it actually home. Its 2+ hours from here.
Logged
chardrc
Member
Online Online
« Reply #7 on: February 03, 2007, 04:43:48 PM »
looks little heavy for off road mus.. but then again if you put an improvised bed in the back and a front axle maybe some different bumpers it could be a sweet offloading machine.
Logged
Midwest MudslingerŽ
Member
Offline Offline
WWW
« Reply #8 on: February 03, 2007, 05:23:21 PM »
Hard to tell how small it was from the pics as I've never seen one before, would be kind of a pain in the ass with a 80" wheelbase. Thought it was longer like a FSJ. Definately make an interesting wheeler though, nice head start with a diesel.  I like the bobtail rear with the built in tool box. From what I read they used these to pull planes around, tons of low end torque and gutless on the road with the 3.3 diesel. Aside from getting it running, what were you planning on doing with it?
Here's a better side shot of one for those like me who thought it was bigger...
Logged
lanulos89
Member
Offline Offline
« Reply #9 on: February 03, 2007, 06:04:00 PM »
cool looking but like everyone else said why did you buy it?? what are your plans?Huh?Huh?
Logged
Steve-
new rig- 1997 tj 5spd, 1 3/4" spacers  front discos cutoms led tails, rear clicky locker, diff guards, and other various do hickies
old rig-1995.5 yj, auto,4.10's,  4" lift, 1" body 33" bfg muds, full pacesetter xhaust,  CAI, lots of lights no sway and track bars rear clicky locker led ta
chardrc
Member
Online Online
« Reply #10 on: February 03, 2007, 07:03:00 PM »
wow that makes it look a lot smaller... like my jeep with a massed up grill adn a Frankenstein towing rearend...  now i see why you would buy one.
Logged
Jeffy
#1 FanŽ
Member
Offline Offline
« Reply #11 on: February 03, 2007, 08:27:57 PM »
Quote from: "jagular7"
Don't get rid of the grill and fenders!  If you have to, you can use a CJ grill and have the headlights on the grill, but honestly, I'd rather have wider headlights and actually work.  The doors have export YJ.  Notice they are square in the upper rear corner.  These are different then YJ full doors.
if I had a project, I'd consider sourcing a Corporate 14 bolt and D60 or maybe a Jtruck D44/D60 combo.  Go full width then wrangle them in with negative offset wheels.
This is the coolest one I've seen;
Logged
jagular7
Member
Offline Offline
« Reply #12 on: February 04, 2007, 09:33:58 AM »
Here is a LINK to one that is being reconfigured right now. Wagoneer-like frame, Wagoneer axles bolt right in, reconfiguration on rear suspension, longer wheelbase, swap in 208, custome bed design, 34x9.5s due to the full front fenders.....
Cost? I got it for under $1200 total ($1007+10%+tax). Right now, I'm just trying to get a buddy with a trailer to go get it with me as I don't have a tow vehicle and trailer. I still got to explain it to my wife. If I can get it to run cheaply, I'll spend time getting it together with a bed, longer wheelbase, 4wd, etc. I've already got another project sitting in the garage and a running TJ on the street. I still think it was cheap enough. The diesel is suppose to get better than 25 mpg properly geared/tired.
Why? I jokingly bid on it. It was originally listed for an auction back in late December. I've got buddy who took a Tracker and built it for WERock competition. I suggested he go with something like this so he suggested I bid on it. Then it got pulled due to not being listed as sealed bid. It was re-listed as sealed bid and closed last Friday. I sent in my bid and won. I was surprised as these would sell for over $2k or more non-running in the past.
Logged
Jeffy
#1 FanŽ
Member
Offline Offline
« Reply #13 on: February 04, 2007, 11:29:34 AM »
http://www.cj-8.com/forum/attachment.php?attachmentid=8455&d=1168342208.jpg
Hmm, that does look nice.  I like how they used Wagoneer leafs so it moves the axle automatically rearward.  Is that guy going to put a Jeep trailer on the back?
Logged
aw12345
Member
Offline Offline
WWW
« Reply #14 on: February 04, 2007, 12:20:15 PM »
Hi there first prime the fuel system. Then see if it has some sort of electric shut off on the injection pump and see if theat has power to it.
If so loosen one of the injector lines crank it see if it spits diesel if so give her a little go go juice like wd 40 or some alchohol based parts cleaner or starting fluid. I like tha last one least since its kinda harsh on the engine.
Some spray cans of brakecleen make a good starting fluid also makes em rattle in a heart beat
Art
Logged
Pages: [1] 2 3 ... 6   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
SMF Theme © Gaia
Valid XHTML 1.0! Valid CSS!
