4bangerJP.com
May 22, 2012, 08:10:57 PM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News: New Smiley and Message Icons!
   Home   Help Login Register
Pages: [1]   Go Down
  Print
Author Topic: Here's my 97 TJ w/ new shoes  (Read 1074 times)
jagular7
Member
Offline Offline
« on: September 17, 2005, 07:27:10 PM »
It's got the 4cyl/auto, 3.73's and a real tired tranny. 35x10.5's on 15x7 w/4" bs. Tires wouldn't fit the stock 6" rims on the rear axle. 30* ramp. Very little flex out of front. Lots on rear. Forgot to measure for exact shock length on the rear. Road the bump stop on rear axle both times. Stock bump stop on rear. ACOS in front, 2" spacer rear, Unlimited coils. Front raised block on axle didn't even come close to being touched.
**Hope the pic links work. Doesn't show on preview.
Logged
Jeffy
#1 FanŽ
Member
Offline Offline
« Reply #1 on: September 18, 2005, 12:53:36 AM »
Fixed it for you.  Spaces in URL's are represented by a %20, otherwise they won't work.
Hmm, they make a 35?  I've only seen 34x9.5R15 TSL or 34x10.5R15 LTB's?  I run a 34x9.5R15 TSL for a spare.  It measures as tall as my 35" MTR.  I'd suspect a 35" TSL would be closer to 36" Radial.
Logged
Youtube Channel: http://www.youtube.com/user/4bangerjp
"If the motor car were invented today, there is absolutely no way that any government in the world would let normal members of the public drive one." -Jeremy Clarkson
StefanBidi
Guest
« Reply #2 on: September 18, 2005, 06:29:55 AM »
Looks very nice!  Quite a bit of flex on the rear.
BTW, Interco also offers the SSRs in 35x10.5".
Logged
jagular7
Member
Offline Offline
« Reply #3 on: September 19, 2005, 09:09:38 PM »
Quote from: "Jeffy"
Thanks. Got to remember that.
No 35" LTBs, typo they are 34's. I was thinking of going with the Q78-15 but wasn't sure on the width side. Wheels are cheap had in the shop 15x7's. I think the Q78's would fit better on a 8" rim with the 4" bs. Maybe next time. I was going to go with the 9.5's but was able to get the 10.5's much cheaper (~$50/ea).
Drove it home 60+ miles in a headwind. I definately need to get gears. Had it mostly in 2nd going 50mph (I think-speedo is not adjusted) just to keep some kind of pace.
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
SMF Theme © Gaia
Valid XHTML 1.0! Valid CSS!
