4bangerJP.com
May 23, 2012, 05:10:10 AM *
News: Don't feed the Trolls
   Home   Help Login Register
Pages: 1 [2]   Go Down
  Print
Author Topic: Soon to be installed cruise control  (Read 879 times)
jfrabat
Gargantuan Mango Tree MechanicŪ
Member
Offline Offline
Finally USING the Jeep!
« Reply #15 on: December 28, 2011, 07:35:05 AM »
those are def the same, how come you didn't use the factory VSS?
What's VSS?  I just follow3d rhe instructions for the install...
Logged
sharpxmen
Chief Squirrel BlowerŪ
Member
Offline Offline
« Reply #16 on: December 28, 2011, 08:05:45 AM »
VSS = Vehicle Speed Sensor,you can use the factory sensor, the ECM (PCM) signal or their crank magnetic pickup kit - i assumed you used their pickup kit when you mentioned reusing the sensor.
Logged
jfrabat
Member
Offline Offline
« Reply #17 on: January 03, 2012, 07:20:07 AM »
No, I used the PCM...  What I mean is that I dont need to take out everything that is wired (including the keypad) because the connection seems to be the same (and since it is the same manufacturer, it probably IS the same).
Logged
reddogg
Member
Online Online
« Reply #18 on: January 03, 2012, 07:28:49 AM »
I installed cruise on my yj a couple of yrs ago. It works great, haven't had any problems with it. It's a CCS 100 by audiovox.
« Last Edit: January 03, 2012, 07:30:12 AM by reddogg » Logged
95 yj 2.5 227000 and counting. 4.0 TB, alternator upgraded, cruise control, electric fan, winch and more to come as funds permit.
71 VW Super Beetle Convertible. bone stock.
71 VW Westy - a work in progress
Pages: 1 [2]   Go Up
  Print
Jump to:
SMF Theme © Gaia
Valid XHTML 1.0! Valid CSS!
