4bangerJP.com
May 23, 2012, 05:36:03 AM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News: New Smiley and Message Icons!
   Home   Help Login Register
Pages: 1 [2]   Go Down
  Print
Author Topic: '99 TJ - Her first pic  (Read 1629 times)
Gold Member
Guest
« Reply #15 on: August 03, 2008, 11:21:18 PM »
did u ever figure out the bushings cause mine did the same exact thing
what did you do
I replied to your PM :)
Basically, the company that made the bushings for SkyJacker messed up.  They made a batch of bushings that had too much air added during the manufacturer process (or something like that), causing them to disintegrate.
I called SkyJacker and they sent me some new bushings.  So far so good.
Logged
Gold Member
Guest
« Reply #16 on: August 16, 2008, 09:27:20 PM »
How do you think this would look on the side of my Jeep?
Yay or nay?
[attachment deleted by admin]
Logged
willbacker45
Guest
« Reply #17 on: August 16, 2008, 09:36:42 PM »
Yay or nay?
lol thats hilarious id say its your jeep do whatever you want with it  thumb
we are basically running the same setup wheels tires shocks the whole nine yards lol, i added a .75in coil isolator to the front to level it out and i think it looks awesome now and it was 18.99 lol so just an FYI if you ever wanted to level it but yours may already be idk
Logged
Gold Member
Guest
« Reply #18 on: August 16, 2008, 09:47:56 PM »
Thanks...thought it would be a fun thing to do...
I so need to level mine out....I'll definitely look into that coil isolator thing.  Are they easy to fit?
Logged
willbacker45
Guest
« Reply #19 on: August 16, 2008, 10:54:05 PM »
ya its just .75in more i used ratchet straps to compress my springs that helped alot also having my 240lb dad stand on the axel while i put the spring in helped alot...all i disconnected was my sway bar links and my shocks
Logged
Pages: 1 [2]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
SMF Theme © Gaia
Valid XHTML 1.0! Valid CSS!
