4bangerJP.com
May 23, 2012, 05:41:22 AM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News: Did You read the FAQ?        ...most likely not...        ...why not try it?
   Home   Help Login Register
Pages: [1]   Go Down
  Print
Author Topic: I installed my new intake last night.  (Read 1241 times)
95yjman
Member
Offline Offline
Phat YJ
WWW
« on: August 18, 2008, 12:32:09 PM »
Well I got home from work last night and put this on
I'm pretty happy with it, it seems like its really opened things up some. I still have to install my 4.0tb.  Should I do a throttle body spacer or call it good?
Logged
Trail Jeep: 95 YJ, 33's, 4:88's, spooled D44 rear, BDS Lift
Baby Jeep: 04 KJ, mopar skid plates, front tow hooks
Daily Driver/tow rig: 2005 Ford F-350
Member
Offline Offline
« Reply #1 on: August 18, 2008, 02:59:46 PM »
I'd do the TBS.
Logged
neale_rs
Member
Offline Offline
« Reply #2 on: August 18, 2008, 03:21:42 PM »
Looks good.  I got a 4.0 TB a while back and plan to install it without a spacer.  The only advantage seems to be that it provides you with the required gaskets.
Logged
'95 YJ, 33 x 12.5 BFG MTs, RE 4.5 ED lift, Atlas 4 speed, CV DS, rear D44 w/ ARB, 4.56 gears, 8000# winch, track bars removed
Member
Offline Offline
« Reply #3 on: August 18, 2008, 07:22:01 PM »
Look on Ebay you can get one with gaskets for $20.  Thats an expensive way to get gaskets but it should do a little more than that Huh?
Logged
95yjman
Member
Offline Offline
Phat YJ
WWW
« Reply #4 on: August 19, 2008, 08:23:13 AM »
I'm not saying this gave me "throw ya back in your seat" power but I can tell a difference.  I'll look into some other stuff.  heh
Logged
neale_rs
Member
Offline Offline
« Reply #5 on: August 19, 2008, 08:27:31 AM »
A spacer probably won't hurt but all the published dyno tests I've seen don't show much of a benefit.  It seems to be something that just doesn't deliver enough for what it costs.
Logged
95yjman
Member
Offline Offline
Phat YJ
WWW
« Reply #6 on: August 19, 2008, 04:41:26 PM »
What all mods do you have done to your motor? What did you get your Dana 44 out of thats under your Jeep now?
Logged
neale_rs
Member
Offline Offline
« Reply #7 on: August 20, 2008, 06:30:54 AM »
The only motor mods I've done, if they can even be called that, are remove the "flow restrictor" in the stock air intake, put in a distributor cap with brass terminals, install a thermostat (this actually helped because it was running cold all the time before), and put in a new computer when the original one went bad (the idle improved a lot).  The other mod that has helped is the 4.56 gears.  The Dana 44 is from a Cherokee.  These have the right width and bolt pattern.  The larger brakes it came with allow it to brake with 33s just as well or maybe a bit better than it did with 30s and the dana 35.
Good luck with your mods.
Logged
I Ride Naked
Guest
« Reply #8 on: August 26, 2008, 09:16:54 PM »
As much mud as I see in that engine bay you may want to get a pre-filter for that air filter.
Logged
acousticrawk
Member
Offline Offline
no text to display
« Reply #9 on: August 27, 2008, 03:40:21 AM »
why dont you turn it towards the drivers side fender? where its at, it will suck up a ton of heat from the exhaust manifold.
Logged
95yjman
Member
Offline Offline
Phat YJ
WWW
« Reply #10 on: August 27, 2008, 01:07:09 PM »
I don't know its just where it sits heh
Got one, just haven't put it on yet and haven't done any wheelin lately.  I live in Indiana is why there is so much mud in there.  I'm starting to get away from all the mud though...I really like playin on the rocks down at the Badlands Cool
Logged
bvincent
Newbie
Offline Offline
« Reply #11 on: October 09, 2008, 08:19:06 PM »
FWIW    I installed the 4.0 TB without a spacer, It ran better but it had a slight hesitation on acceleration.
I didn't want to pay $75 bucks for a $2 piece of aluminum. I found one on e-bay for $30 with shipping.
With the spacer on, the hesitation went a way and it ran better.
Make sure you get the spacer for the 4.0.
Logged
"Go Ahead Skin that Smoke Wagon and see what Happens"
"You gonna stand there and bleed or do something"
Wyatt Earp - Tombstone
95yjman
Member
Offline Offline
Phat YJ
WWW
« Reply #12 on: October 09, 2008, 08:21:00 PM »
Ya I still need to get a cap for my MAP sensor area in order to install my 4.0 TB  Roll Eyes
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
SMF Theme © Gaia
Valid XHTML 1.0! Valid CSS!
