4bangerJP.com
May 23, 2012, 05:47:10 AM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News: You didn't read the FAQ did you?                                      ...Why not check it out?
   Home   Help Login Register
Pages: [1]   Go Down
  Print
Author Topic: my stretched 4banger TJ  (Read 1499 times)
Po' Boy
Guest
« on: November 17, 2005, 08:31:07 PM »
Here's my 99' 4banger.........
Matt
Logged
Jeffy
#1 Fan®
Member
Offline Offline
« Reply #1 on: November 17, 2005, 08:34:45 PM »
A member of the Pirate4x4 Forum perhaps?
What's you're wheelbase at?  I've thought about doing a stretch but I'd like to do it the hard way and cut the frame.  Good thing I don't have the tools here to do it.   lol   I'd like more interior room to go along with teh 10" of increased wheelbase. :wink:
Logged
Youtube Channel: http://www.youtube.com/user/4bangerjp
"If the motor car were invented today, there is absolutely no way that any government in the world would let normal members of the public drive one." -Jeremy Clarkson
SMC4WD
Guest
« Reply #2 on: November 17, 2005, 08:55:07 PM »
Seeing this pic is bringing up the second time I’ve ever heard of converting coils to leaves…
I own a YJ, and I used to joke all the time about people going backwards and converting to leaves…  I can’t believe that it performs better that way.  Coils extend forever, and the compress till they touch.  Rigid springs that don’t flex (what I drive with) make little sense to me.
But if it’s working, and there’s a lot more people out there doing it, it must be beneficial.  Just weird to me.
Logged
Po' Boy
Guest
« Reply #3 on: November 18, 2005, 10:23:28 AM »
Well, the reason I went to leaves in the rear was partly for stability, but mostly for the simplicity, and was easier to stretch. I thought it was at 104, but after measuring the other day just for the hell of it, its at exactly 102". The springs flex fine, but I seem to be a bit tall. I'm running RE 5.5 springs up front. I'm going to set this rig down using 3.5" XJ leafs SUA (SOA now) in rear, and prolly 4.5" coils up front. It does great, but I think the lower COG will help out alot.
Matt
Logged
Bounty Hunter
Member
Offline Offline
WWW
« Reply #4 on: November 21, 2005, 07:50:21 PM »
Strange way to mount shackle hangers, but if it works....
You mentioned a 4-link front suspension, isn't it a 3-link with radius Y arms and a trackbar?
Logged
moerl8088
Guest
« Reply #5 on: November 21, 2005, 09:16:47 PM »
Nice decal on the tail gate  :D
Logged
Po' Boy
Guest
« Reply #6 on: November 22, 2005, 06:40:43 AM »
Quote from: "Bounty Hunter"
Yeah, its just RE's stuff up front, radius arm style, not really a 4link. The shackle hangers are bolted on to the bumper, and the nuts are welded on the backside of the bumper. No probs at all with it. Like I say though, I'm dropping it down a bit using 3.5" 's SUA, so it may change.
Matt
Logged
rojogordo
Guest
« Reply #7 on: January 14, 2006, 03:13:30 PM »
What is the rationale behind the stretch?
Logged
Jeffy
#1 Fan®
Member
Offline Offline
« Reply #8 on: January 14, 2006, 03:35:48 PM »
Longer wheelbase makes the vehicle more stable when climbing.  Tt also gives you a bit more room for longer drivetrain.
Logged
low output 2.5
Guest
« Reply #9 on: January 16, 2006, 11:18:35 PM »
with the height your looking for you should look into s10 springs preferbly stock  soa the flex like crazy and a little longer than what your runnin my 02 $
Logged
Po' Boy
Guest
« Reply #10 on: January 20, 2006, 09:12:53 AM »
Quote from: "low output 2.5"
Do you happen to know the length of the S10's? I believe they are a 3 leaf pack with an overload, correct?
Logged
Po' Boy
Guest
« Reply #11 on: January 20, 2006, 09:21:50 AM »
A couple changes to the jeep since I posted that pic. I milled the shackles down, and redrilled them to lower the rear about 1.5". Added some 1.5" spacers up front, and got some new shoes. I fabbed up some new aluminum front fender wells that move the opening back a few inches.
Here is the link to the project thread:
http://www.jeepforum.com/forum/showthread.php?t=217266
And some pics for those who don't click on the link:
Logged
low output 2.5
Guest
« Reply #12 on: January 20, 2006, 09:37:23 AM »
s10 springs are about  2-3 inches longer with a lil arch about 2 inches taller than a stock xj spring
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
SMF Theme © Gaia
Valid XHTML 1.0! Valid CSS!
