jfrabat
Gargantuan Mango Tree Mechanic®
Member
Offline
Finally USING the Jeep!
« on: November 15, 2008, 02:30:34 PM » |
OK, so I did some work today on the Jeep (changed the thermostat housing's gasket, adjusted the brake booster travel, installed the front drive shaft back and put in new U-Joints, etc.) and after I was done, I took the Jeep for a test drive on the streets behind my house (which leads to a rock quary). Anyway, I was driving around, and saw a nice rock on the side of the street, and decided to use the phone's camera to take some poser shots... So I disconnected the swaybar links, loosened the telescopic track bar, put the jeep in 4L and turned the lockers on (I tried without the lockers first, but it was much easier with the lockers on!), climbed up the rock and took these. I think articulation is not all that bad, even considering the 4" lift springs...     By the way, it is not snow in the ground; it is dust from the quary (rocks here are white, and it never snows in Miami), and I did turn the aux lights on (got to look GOOD while posing, right?)... Felipe
Logged
'94 YJ 2.5L with 4" RE lift, Adv. Ad. SYE, Woody Shaft, Superwinch EPi9.0, 62mm TB, FoMoCo e-Fan, SD30 and SD35 w/ARB-4.88, 165A alt., 4 KC aux lights, Aluminum Rad, BRX hoses, 33" BFG KM2 on 15" AR wheels, Sony sound system, Pavement Ends Hardtop, Bosch 19# Injector, Safari Snorkel, Hydroboost
Mozman68
Poseur Extraordinaire®
Member
Offline
« Reply #1 on: November 16, 2008, 02:43:07 PM » |
damn that rig is clean...
Logged
2000 TJ...4" Full Traction long arm, ORO swayloc, HP D60's front and rear, 35x12.5 Trxus MT's on 17x9 AR Teflon Chambers, Hunsaker front seats, ARB lockers front and rear, JCR off road flat fenders, sliders, rear fenders installed over PSC crusher corners
chardrc
Member
Offline
« Reply #2 on: November 16, 2008, 03:34:02 PM » |
nice shots.... its amazing how clean vehicles can be when they aren't bombarded with salt all winter long.
Logged
1990 YJ 4cly, ax5, 2.5 inch BDS lift, 31 MTr's, Powertrax-lockers all around, track-bars removed, boomerang shackles, warn m8000 winch, electric fan.
95yjman
Member
Offline
Phat YJ
« Reply #3 on: November 16, 2008, 07:54:17 PM » |
That thing is clean! Looks good man
Logged
Trail Jeep: 95 YJ, 33's, 4:88's, spooled D44 rear, BDS Lift
Baby Jeep: 04 KJ, mopar skid plates, front tow hooks
Daily Driver/tow rig: 2005 Ford F-350
jfrabat
Member
Offline
« Reply #4 on: November 17, 2008, 08:30:02 AM » |
Well, one of the reasons I decided to buy the rig in the first place is that it was a very clean Jeep, no rust at all. I have also added a lot of things that make it cleaner, like the hardtop, but the softtop is also in excelent condition (I think it was fairly new when I bought it). I am thinking about selling the soft top, though, as I never use it anymore...
Logged
neale_rs
Member
Offline
« Reply #5 on: November 18, 2008, 08:01:11 AM » |
Looks good! I'm sure it has more articulation, just need to get it on a bigger rock!
Logged
'95 YJ, 33 x 12.5 BFG MTs, RE 4.5 ED lift, Atlas 4 speed, CV DS, rear D44 w/ ARB, 4.56 gears, 8000# winch, track bars removed
stan98tj
Empty Wallet Wheeling Since 2007®
Member
Offline
Wheeling CT/Long Island
« Reply #6 on: November 25, 2008, 08:15:30 AM » |
if i lived in florida i think i would just be doorless and topless all day every day...maybe id purchase a bikini top, but aside from that i would pretty much be open everyday...much like how i am durin the summer up here in CT-i hate the arrival of fall when i have to button her back up again.
Logged
98 TJ 33"Toyo, new long block lol,RoughCountry 3.25"+1"BL,IronMan Fab control arms,4.56gears,Ford 8.8,WARN VR10,EATON front locker,Body Armor Rock Rails WISHLIST:TDi.Girlfriend hates it :) If you can read this don't flip me over i dont have any $$ left to fix it
Mozman68
Member
Offline
« Reply #7 on: November 25, 2008, 08:33:28 AM » |
Teah...but in Florida you've got to worry about all those Panamanians running around stealing stuff out of your rig....
Logged
jfrabat
Member
Offline
« Reply #8 on: November 27, 2008, 06:06:00 AM » |
Teah...but in Florida you've got to worry about all those Panamanians running around stealing stuff out of your rig....  Well, how else are you supossed to get stuff for your rig? After all, buying is SO out of style (with the economy and what not)...
Logged
TN00TJ
Member
Offline
« Reply #9 on: January 16, 2009, 03:28:16 PM » |
Good looking rig - for a dd it flex's pretty good from the look of the pic.
Logged
jfrabat
Member
Offline
« Reply #10 on: January 16, 2009, 03:33:07 PM » |
I can probably get it to flex more; I just need to find a bigger rock!
Logged
perrychop
Newbie
Offline
« Reply #11 on: July 20, 2010, 02:23:45 PM » |
dang..that's a nice rig...
Logged
jfrabat
Member
Offline
« Reply #12 on: July 20, 2010, 04:38:30 PM » |
« Last Edit: July 20, 2010, 04:40:04 PM by jfrabat »
Logged
TahoeYJ
Member
Offline
How can I reech theese kids?
« Reply #13 on: August 07, 2010, 04:58:31 PM » |
More pics of the Jeep behind you??? Never seen a headlight set-up quite like that...
Logged
Jeffy
#1 Fan®
Member
Offline
« Reply #14 on: August 07, 2010, 05:15:55 PM » |
It's a CJ-10 grill.
Logged
