4bangerJP.com
May 23, 2012, 05:54:47 AM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News: 4BangerJP.com Stickers Now Available!
   Home   Help Login Register
Pages: [1]   Go Down
  Print
Author Topic: Did a little work to the Jeep this weekend.  (Read 1155 times)
95yjman
Member
Offline Offline
Phat YJ
WWW
« on: November 16, 2008, 09:14:52 PM »
I did a little work to the Jeep and ended up with this, not so bad
and this too
and did anybody know that the rear track bar is hollow inside?  Huh?
Anyway, I put on a 2"BDS kit and SYE, gotta get my cherokee front drive shaft choped down now and put that in.
oh and for a before and after for those don't see my jeep to often
Logged
Trail Jeep: 95 YJ, 33's, 4:88's, spooled D44 rear, BDS Lift
Baby Jeep: 04 KJ, mopar skid plates, front tow hooks
Daily Driver/tow rig: 2005 Ford F-350
aw12345
Member
Offline Offline
WWW
« Reply #1 on: November 17, 2008, 12:02:16 AM »
Making excelent progress with your Jeep
Logged
jfrabat
Gargantuan Mango Tree Mechanic®
Member
Offline Offline
Finally USING the Jeep!
« Reply #2 on: November 17, 2008, 09:03:01 AM »
Looking good, man!
Logged
'94 YJ 2.5L with 4" RE lift, Adv. Ad. SYE, Woody Shaft, Superwinch EPi9.0, 62mm TB, FoMoCo e-Fan, SD30 and SD35 w/ARB-4.88, 165A alt., 4 KC aux lights, Aluminum Rad, BRX hoses, 33" BFG KM2 on 15" AR wheels, Sony sound system, Pavement Ends Hardtop, Bosch 19# Injector, Safari Snorkel, Hydroboost
95yjman
Member
Offline Offline
Phat YJ
WWW
« Reply #3 on: November 17, 2008, 05:51:46 PM »
Thanks guys!  I'm pretty happy with it.  I dropped my cherokee front shaft off today to get shortend, so it should be done tommrrow.
Logged
neale_rs
Member
Offline Offline
« Reply #4 on: November 18, 2008, 08:05:27 AM »
It's looking like a serious offroad machine now!
Logged
'95 YJ, 33 x 12.5 BFG MTs, RE 4.5 ED lift, Atlas 4 speed, CV DS, rear D44 w/ ARB, 4.56 gears, 8000# winch, track bars removed
chardrc
Member
Offline Offline
« Reply #5 on: November 18, 2008, 06:11:15 PM »
looks really good... how much lift do those shackles have? i have the same kit with 31's and mine has allot less fender room... well i guess your 1 inch body lift helps... now the work is done. go out and have some fun.  thumb dance
Logged
1990 YJ 4cly, ax5, 2.5 inch BDS lift, 31 MTr's,  Powertrax-lockers all around, track-bars removed, boomerang shackles, warn m8000 winch, electric fan.
95yjman
Member
Offline Offline
Phat YJ
WWW
« Reply #6 on: November 18, 2008, 07:41:03 PM »
Shackles are about 1-1.5" of lift.  I plan too fun with her!
Logged
FourbangerYJ
Servicing Squirrels Since 1995®
Member
Offline Offline
« Reply #7 on: November 18, 2008, 10:22:43 PM »
It's coming along! Looks good!
Logged
Using tools you have not used in a while is like shaking hands with old friends. nod
95yjman
Member
Offline Offline
Phat YJ
WWW
« Reply #8 on: November 19, 2008, 04:07:29 PM »
Thanks! I got the rear driveshaft put in and everything seems to be fine with that.  Just gotta get the rear brake lines sorted out.
Logged
95yjman
Member
Offline Offline
Phat YJ
WWW
« Reply #9 on: November 20, 2008, 01:42:41 PM »
Here's a picture of my new rear driveshaft.  How does my pinion angle look?  It seems to go down the road just fine.  I want to flex the jeep out and make sure everything still works just fine.
Logged
jfrabat
Member
Offline Offline
« Reply #10 on: November 20, 2008, 01:59:47 PM »
It's a bit difficult to tell from the picture, but it looks aligned...
Logged
95yjman
Member
Offline Offline
Phat YJ
WWW
« Reply #11 on: November 20, 2008, 02:36:08 PM »
Ya it was kinda hard to get a good picture.  It was freezing cold heh
Logged
95yjman
Member
Offline Offline
Phat YJ
WWW
« Reply #12 on: November 23, 2008, 01:49:58 PM »
I got my rear brakeline lowered down a little bit  so I tried to flex it out a little in the front ditch today
First try not so cool heh
Best that I could do for now, I really just wanted to get a feel for the new springs.
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
SMF Theme © Gaia
Valid XHTML 1.0! Valid CSS!
