4bangerJP.com
May 23, 2012, 06:28:01 AM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News: Don't feed the Trolls
   Home   Help Login Register
Pages: [1] 2   Go Down
  Print
Author Topic: Almost completed!!!  (Read 2839 times)
jfrabat
Gargantuan Mango Tree MechanicŪ
Member
Offline Offline
Finally USING the Jeep!
« on: July 18, 2009, 01:39:00 PM »
OK, so ALMOST is the key word here (and it does not seem to be going away anytime soon!), but here is what the Tropical Explorer looks like as of today with the new Warn Trail Flares:
The only VISIBLE change remaining is the A to Z Fab rocker guards, which are getting Line-X'ed as we speak (I also need to instal the Mopar Cam, TCG inertia ring, replace the timing chain, replace the clutch, and extend the spare's bump stops).
Felipe
Logged
'94 YJ 2.5L with 4" RE lift, Adv. Ad. SYE, Woody Shaft, Superwinch EPi9.0, 62mm TB, FoMoCo e-Fan, SD30 and SD35 w/ARB-4.88, 165A alt., 4 KC aux lights, Aluminum Rad, BRX hoses, 33" BFG KM2 on 15" AR wheels, Sony sound system, Pavement Ends Hardtop, Bosch 19# Injector, Safari Snorkel, Hydroboost
dos0711
Guest
« Reply #1 on: July 18, 2009, 01:50:26 PM »
That...and putting the driver's side hood latch back on... Wink
Logged
jfrabat
Member
Offline Offline
« Reply #2 on: July 18, 2009, 01:53:24 PM »
I opened the hood prior to that shot to get to the compressor, but I decided one more shot, so during that shot, I closed only one latch!  Surprised you caught it, though.  It was closed by the time I drove back home, so dont worry!
« Last Edit: July 18, 2009, 01:54:22 PM by jfrabat » Logged
jfrabat
Member
Offline Offline
« Reply #3 on: July 18, 2009, 02:02:40 PM »
Let's do a bit of comparing:
Before:
A bit later (notice the diff cover is now on):
Now:
Logged
dos0711
Guest
« Reply #4 on: July 18, 2009, 02:40:22 PM »
Only a fellow Jeeper would notice... biggrin
Logged
neale_rs
Member
Offline Offline
« Reply #5 on: July 18, 2009, 05:26:55 PM »
It has come a long way and looks great.
Logged
'95 YJ, 33 x 12.5 BFG MTs, RE 4.5 ED lift, Atlas 4 speed, CV DS, rear D44 w/ ARB, 4.56 gears, 8000# winch, track bars removed
sharpxmen
Chief Squirrel BlowerŪ
Member
Offline Offline
« Reply #6 on: July 20, 2009, 10:12:10 AM »
hey, looks great - got a question for you as i can see you got some new nice and shiny poly bump stops in this pic: where'd you get them and for how much (and how big are they over stock)?
Logged
jfrabat
Member
Offline Offline
« Reply #7 on: July 20, 2009, 11:30:21 AM »
I got them from Quadrate (click here to see the Q'tec page).  They are 1" longer than stock, but I like them for other reasons as well:
  • They are not rotted like the OEM one I had on
  • They dont have the hole in the middle where they meet the frame, so the frame will not rust (as it was starting to do; I had to scrape, sand and paint prior to installing thee, paricularly in the front)
  • They have the impact slot, which cushions any axle impact to the bump stops
  • They just look much better!!!!
I spent about $100 on these, and the fit is perfect.
Logged
sharpxmen
Member
Offline Offline
« Reply #8 on: July 20, 2009, 11:53:28 AM »
    mine are also rotted and these look way better - will check them out and hopefully order some today. Took one off yesterday in the back and i had to bring out the shop vac to clean the rust that fell off from under there.
    Logged
    dtoliver
    Member
    Offline Offline
    « Reply #9 on: July 22, 2009, 06:07:15 PM »
    i really like the front bumper, what kind is it? you get it from q-tec?
    Logged
    jfrabat
    Member
    Offline Offline
    « Reply #10 on: July 22, 2009, 06:13:21 PM »
    That's a Hanson Offroad bumper; I got it directly from them (they are not cheap, though).  Q'tec sells it as well, but the shipping was cheaper if I bought direct.
    Logged
    dtoliver
    Member
    Offline Offline
    « Reply #11 on: July 23, 2009, 06:46:02 PM »
    you weren't sh*tin', I just looked  (at)  their prices...that's gonna take a months of saving, but it does make all the difference in yer yj besides the tires
    Logged
    TahoeYJ
    Member
    Offline Offline
    How can I reech theese kids?
    « Reply #12 on: August 01, 2009, 09:00:59 PM »
    looks awesome Felipe, except you need to find a bigger rock to flex it out on  stick  Wink
    Logged
    jfrabat
    Member
    Offline Offline
    « Reply #13 on: August 02, 2009, 03:04:00 PM »
    Yeah, I know...  Problem is South FL is not exactl known for rugged terrain; it is flat as a pancake here!  And that pic was taken at a quary, mind you!  Maybe I'll get some bette pictures down in Panama or Costa Rica.
    Logged
    chrisfranklin
    4BangerJP.comŪ Donator
    Member
    Offline Offline
    « Reply #14 on: August 02, 2009, 07:00:09 PM »
    You setup should be a lot of fun to have in Costa Rica and Panama, Felipe.   By the way, besides the shipping costs, does it cost more to buy after-market parts online and have them shipped there vs. the U.S.?  I just noticed you seemed like you put a lot of money in to your 4banger before making your move down there; was wondering if there were tax advantages or something like that involved in building things up up here vs. down there?
    Logged
    '94 2.5 YJ S 5spd, Borla Cat-Back, CarSound Cat, Ceram. Headers, PDI Ignition, 62mm TB, Airraid intake, 19lb injectors, Sharp's Adjust. FPR, MeanGreen Starter, 210 amp alternator, D30 Aussie, 31" Destination MTs, bunch of armor.
    Pages: [1] 2   Go Up
      Print
    Jump to:
    Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
    SMF Theme © Gaia
    Valid XHTML 1.0! Valid CSS!
