93yjFirstJeep
Member
Offline
My ongoing project
« on: August 02, 2009, 02:08:18 PM » |
Logged
'93 yj, 4.88, 33x12.50, hi flow cat and catback, 4.0tb, 19# injectors, and pretty nice sound system. Always a work in progress
Midwest Mudslinger®
Member
Offline
I need a bigger hammer!
« Reply #1 on: August 02, 2009, 07:04:23 PM » |
Holy crazy long shackles!  Other than that, that is one clean YJ!
Logged
93yjFirstJeep
Member
Offline
My ongoing project
« Reply #2 on: August 02, 2009, 09:24:52 PM » |
i know, the shckles look a little ridiculous, im going to college so now im broke and cant buy a real lift. maybe xmas  i would like to replace that with between a 2.5" and 3.5" suspension lift and maybe a daystar 1" body lift, im thinking the red bushings would look good
« Last Edit: August 02, 2009, 09:37:21 PM by 93yjFirstJeep »
Logged
sharpxmen
Chief Squirrel Blower®
Member
Online
« Reply #3 on: August 02, 2009, 10:10:13 PM » |
i know, the shckles look a little ridiculous, im going to college so now im broke and cant buy a real lift. maybe xmas  i would like to replace that with between a 2.5" and 3.5" suspension lift and maybe a daystar 1" body lift, im thinking the red bushings would look good looks good man, but you're right, those shackles are outta this world - i got 33s with 2.5'' lift, 1'' shackles and 1'' body lift, the 1'' shackles are ok, can't tell their on compared to stock, as a matter of fact i had the lift befoe i installed them and the ride got smoother once i put them on. You can go on a budget with add a leaf if you want, the ride would be stiffer/rougher though.
Logged
93yjFirstJeep
Member
Offline
My ongoing project
« Reply #4 on: August 08, 2009, 02:13:21 PM » |
Logged
stan98tj
Empty Wallet Wheeling Since 2007®
Member
Offline
Wheeling CT/Long Island
« Reply #5 on: August 09, 2009, 12:29:02 AM » |
nice and clean..i like it
Logged
98 TJ 33"Toyo, new long block lol,RoughCountry 3.25"+1"BL,IronMan Fab control arms,4.56gears,Ford 8.8,WARN VR10,EATON front locker,Body Armor Rock Rails WISHLIST:TDi.Girlfriend hates it :) If you can read this don't flip me over i dont have any $$ left to fix it
OH-YJ
Member
Offline
« Reply #6 on: August 09, 2009, 05:00:52 PM » |
That is a very clean YJ. Looks real sharp (even better when you get a lift and you can drop the shackles  )
Logged
95 YJ, 4.0 TB, 2.5" Lift, 31" MTZ's on MT Classic II's, Magnaflow cat, Borla catback.
jagular7
Member
Offline
« Reply #7 on: August 10, 2009, 01:52:51 PM » |
Take a look at those shackle bolts both the frame and spring. They shouldn't be tightened to squeeze into the bushing. The bushing needs space to flex. Take one bolt out at a time, add some anti-seize to the bolt body and put back in. The anti-seize will act as a lubricant to the inner tube bushing. From the rear picture, the rear spring has more bend in it than the shackle has movement. This creates a binding effect and a stiff ride.
Logged
Jagular7 97 SE - Rubbered and locked for fun
93yjFirstJeep
Member
Offline
My ongoing project
« Reply #8 on: August 10, 2009, 05:00:43 PM » |
i noticed that but i just assumed it was because i didnt remove the track bars for that pic
Logged
jagular7
Member
Offline
« Reply #9 on: August 12, 2009, 06:07:49 AM » |
Yah, track bars with leafs will probably do the same thing. I thought I had read you removed them someplace. But still check those shackle bolts especially if you didn't install them. same for the frame mounts on the leafs. You never know what the PO tightened when they were underneath it.
Logged
93yjFirstJeep
Member
Offline
My ongoing project
« Reply #10 on: August 12, 2009, 06:54:26 PM » |
i did have the bars off, but didnt like the way it handled and i do 99.9% of my driving on the street so i put them back on. is there a torque spec for those bolts?
Logged
95yjman
Member
Offline
Phat YJ
« Reply #11 on: September 15, 2009, 08:32:48 PM » |
lol nice pictures
Logged
Trail Jeep: 95 YJ, 33's, 4:88's, spooled D44 rear, BDS Lift
Baby Jeep: 04 KJ, mopar skid plates, front tow hooks
Daily Driver/tow rig: 2005 Ford F-350
sharpxmen
Member
Online
« Reply #12 on: September 15, 2009, 09:13:09 PM » |
download the FSM from the FAQ section - all the torque values are there.
Logged
