4bangerJP.com
May 23, 2012, 06:45:24 AM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News: Don't feed the Trolls
   Home   Help Login Register
Pages: 1 [2]   Go Down
  Print
Author Topic: Banks exhaust+header installed, pic+vid  (Read 2037 times)
FourbangerYJ
Servicing Squirrels Since 1995®
Member
Offline Offline
« Reply #15 on: October 02, 2009, 04:59:47 PM »
yea i know...usually clean, wheeled a week before i put the exhaust in. Im usually nervous about sprayin down the engine bay, but i think im gonna do it soon.
Just becarefull of the air intake. You don't want to get to much water in there. A plastic grocery bag works well to keep it dry. Spray on some simple green let it sit for a bit and hose it down.
Logged
Using tools you have not used in a while is like shaking hands with old friends. nod
BarneyJeep
Member
Offline Offline
« Reply #16 on: October 02, 2009, 05:24:21 PM »
pull back and take a pic from underneath, i would like to see how the cross pipe runs...is it underneath the trans? the bell housing? in front of the oil pan?
Thanks, Rob
Logged
stan98tj
Empty Wallet Wheeling Since 2007®
Member
Offline Offline
Wheeling CT/Long Island
« Reply #17 on: October 02, 2009, 05:42:18 PM »
Thanks, Rob
by cross pipe what exactly do you mean? the down pipe that runs off header to cat?
Logged
98 TJ 33"Toyo, new long block lol,RoughCountry 3.25"+1"BL,IronMan Fab control arms,4.56gears,Ford 8.8,WARN VR10,EATON front locker,Body Armor Rock Rails WISHLIST:TDi.Girlfriend hates it :) If you can read this don't flip me over i dont have any $$ left to fix it
BarneyJeep
Member
Offline Offline
« Reply #18 on: October 03, 2009, 04:53:36 PM »
yup...that'd be the one
Logged
stan98tj
Member
Offline Offline
« Reply #19 on: October 03, 2009, 08:50:02 PM »
sure ill take a few pics in a day or two.
Logged
stan98tj
Member
Offline Offline
« Reply #20 on: October 05, 2009, 03:58:27 PM »
hope these work out better for ya
Logged
BarneyJeep
Member
Offline Offline
« Reply #21 on: October 05, 2009, 05:09:21 PM »
hrm.....much better then the Pacesetter header i have....Thanks!
Logged
stan98tj
Member
Offline Offline
« Reply #22 on: October 05, 2009, 06:33:54 PM »
if you do decide to change over to banks, call the factory directly at their california location ( i can get ya the number if ya need ) and order it directly from them...this way ya dont pay tax on it and shipping may still be free..though i dont know if you can still get the sale price. it's worth a call if you are interested in switching over. Im prob gonna change my cat since it has a leak in it and is showing age..banks doesnt make one though.
Logged
stan98tj
Member
Offline Offline
« Reply #23 on: October 27, 2009, 07:07:12 PM »
this 4bangers sounds great being stock.  I had just recently punched my motor 20 over and det the timing and that things sounds awesome with a thrush welded i installed myself in just 15 minutes. ill get a vid next week and post it. This tj sounds good though, i like the finish on that muffler oopposed to my 39.99 thrush welded. what does the banks monster run? does it come available for 2 1/2 inch pipes?
the banks monster cat back is 2.5". that's the one i have pictured on this post. i need to replace the cat as there is a nice crack in it. once that is taken care of it should actually sound a bit better and the performance may increase a bit-though i prob wont notice.
Logged
hozer
Member
Offline Offline
« Reply #24 on: November 29, 2009, 11:47:44 AM »
The stuff in a can with cotton in it is called Never Dull, that works pretty good. I would reccomend using mothers paste polish that stuff works better. If you are having issues with the tip yellowing and bluing. There is a liquid called Blue Away. I use that on the pipes on my Harley. Get in nice and clean and use gloves or when it gets hot, the oils from your hand will burn into it when it gets hot. If you polish it and put a good coat of hard paste wax on it you shoukd be fine with it staying shiny.
Logged
brokenwrist21
Member
Offline Offline
« Reply #25 on: November 30, 2009, 12:23:06 AM »
sounds kind of like a cross between a rice rocket and one of those 80's military style video games. the camera mic did it no justice. a better sound clip would be awesome. other than that makes me wannt stay with my plans of a full flowmaster header back exhuast. also take it to an exhaust shop or someone who can weld stainless really good, and dump those clamps and seal up the exhuast leaks.
Logged
chrisfranklin
4BangerJP.com® Donator
Member
Offline Offline
« Reply #26 on: November 30, 2009, 04:07:10 AM »
80's style military games -- I like that as a comparison with the 2.5 exhaust sound; it's the best I've read  lol
I tried to describe it as "rice rocket" myself, but just couldn't quite do it --  the 2.5 just doesn't have the "rockets'" high-rpm predilection and you can detect the 2.5s cylinder-volume difference from the "rockets" in the 2.5s' exhaust tones.
« Last Edit: November 30, 2009, 04:09:03 AM by chrisfranklin » Logged
'94 2.5 YJ S 5spd, Borla Cat-Back, CarSound Cat, Ceram. Headers, PDI Ignition, 62mm TB, Airraid intake, 19lb injectors, Sharp's Adjust. FPR, MeanGreen Starter, 210 amp alternator, D30 Aussie, 31" Destination MTs, bunch of armor.
stan98tj
Member
Offline Offline
« Reply #27 on: November 30, 2009, 09:23:40 AM »
im gonna be replacing the cat and then i plan on welding (or having my buddy who welds well  Wink ) seal up all the piping. The sound clip isnt the greatest and i truly does sound better in person, but the biggest thing i like is the fact it isnt too LOUD! the dynomax was downright annoying.
Logged
Pages: 1 [2]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
SMF Theme © Gaia
Valid XHTML 1.0! Valid CSS!
