4bangerJP.com
May 23, 2012, 07:24:03 AM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News: Welcome to 4BangerJP.com...                                         New Members check in at the, "Introduce yourself" thread...
   Home   Help Login Register
Pages: 1 [2]   Go Down
  Print
Author Topic: hunting fishing or working jeeps  (Read 2625 times)
Banshee600
Member
Offline Offline
1992 jeep yj
« Reply #15 on: April 15, 2010, 05:17:06 PM »
hers mine with the pontoon boat
Logged
92 yj 3.5 tuff country lift , 32x11.50 bfg power trax locker rear. cable pull front diff lock, warn m8000 winch, hi lift jack, sound bar kenwood cd am/fm ,cb, GPS And now a {BOUNTYHUNTER }62mm tb and spacer
Midwest MudslingerŽ
Member
Offline Offline
I need a bigger hammer!
WWW
« Reply #16 on: April 15, 2010, 05:40:56 PM »
Couple guys from my club doing trail work at McCaslin Mtn in Lakewood, WI
Logged
Jeffy
#1 FanŽ
Member
Offline Offline
« Reply #17 on: April 15, 2010, 06:07:33 PM »
Full Pull!
« Last Edit: April 15, 2010, 06:07:49 PM by Jeffy » Logged
Youtube Channel: http://www.youtube.com/user/4bangerjp
"If the motor car were invented today, there is absolutely no way that any government in the world would let normal members of the public drive one." -Jeremy Clarkson
sharpxmen
Chief Squirrel BlowerŽ
Member
Offline Offline
« Reply #18 on: April 15, 2010, 06:48:07 PM »
are they leveling the road?
Logged
Midwest MudslingerŽ
Member
Offline Offline
WWW
« Reply #19 on: April 15, 2010, 06:56:49 PM »
Dragging rocks and stumps to close trails and block off areas. They're heavier than they look.
Logged
Banshee600
Member
Offline Offline
1992 jeep yj
« Reply #20 on: April 17, 2010, 08:34:58 PM »
you drag them up so some other jackass pulls the off the trail tour blocking?
Logged
4BangerJP.comŽ Donator
Member
Offline Offline
« Reply #21 on: April 18, 2010, 06:55:43 AM »
camping a few years back. surprising I don't have much for pictures of useful use lol but I have used it a lot for trailer pulling "sleds, garbage runs", pick up tool boxes and parts and things, snowplowing, traveling, camping, sure there is other things just can't think of it right now!!
Logged
Member
Offline Offline
« Reply #22 on: April 18, 2010, 06:58:10 AM »
Logged
sharpxmen
Member
Offline Offline
« Reply #23 on: April 18, 2010, 07:13:54 AM »
i wonder if the snow plow had anything to do with your cracked frame
Logged
aw12345
Member
Offline Offline
WWW
« Reply #24 on: April 18, 2010, 02:06:26 PM »
Winching trees uphill to block off illegal trail bypasses in the San Bernardino forest/ Big Bear
Took some rigging but we finally got that bad boy where we wanted it.
« Last Edit: April 18, 2010, 02:14:59 PM by aw12345 » Logged
Member
Offline Offline
« Reply #25 on: April 18, 2010, 02:24:58 PM »
no it was already cracked.  plowing actually didn't make it any worse..
just didn't want to tear my jeep apart when I needed it for plowing.  the jeep didn't leave my yard much this winter anyway other then jeep meets. I drove my truck that I got for cheep witch hauled my sled around most of the season!!  was way nicer then the jeep and trailer.
« Last Edit: April 18, 2010, 02:27:07 PM by Torch_Ind » Logged
Pages: 1 [2]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
SMF Theme © Gaia
Valid XHTML 1.0! Valid CSS!
