4bangerJP.com
May 23, 2012, 03:01:28 PM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News: Read the FAQ.                                      ...Everybody's Doing It!                                  ...Except you!
   Home   Help Login Register
Pages: [1]   Go Down
  Print
Author Topic: Few pics of my tj  (Read 1469 times)
andrew383
Member
Offline Offline
« on: May 25, 2010, 10:51:13 AM »
Figured id post up a few action shots of my rig :)
Logged
97 tj 2.5 5sp
b.hog
4BangerJP.com® Donator
Member
Offline Offline
« Reply #1 on: May 25, 2010, 11:42:11 AM »
Nice jeep,are those swamper tsl radials? I have got em in 31x9.5 and am pretty pleased ,whats your opinion?
Logged
WranglerCOdy
Member
Offline Offline
WWW
« Reply #2 on: May 25, 2010, 12:44:17 PM »
mmmmmmm FLEEXXXXYY!!
Logged
neale_rs
Member
Offline Offline
« Reply #3 on: May 25, 2010, 12:52:58 PM »
Looks good.  What steering mods do you have? It looks interesting.
Logged
'95 YJ, 33 x 12.5 BFG MTs, RE 4.5 ED lift, Atlas 4 speed, CV DS, rear D44 w/ ARB, 4.56 gears, 8000# winch, track bars removed
andrew383
Member
Offline Offline
« Reply #4 on: May 25, 2010, 06:51:23 PM »
Yes there radials and they do ok,not really my first choice tho..Ill be going with km2's next :)
I have the WJ 12" brake upgrade which includes the pass side high steer knuckle... I just used some tube and heims instead of the factory WJ steering...
Logged
97 tj 2.5 5sp
andrew383
Member
Offline Offline
« Reply #5 on: May 25, 2010, 07:08:10 PM »
This one of my favorite set of pics
Logged
97 tj 2.5 5sp
sharpxmen
Chief Squirrel Blower®
Member
Online Online
« Reply #6 on: May 25, 2010, 07:13:16 PM »
i'm doing the same thing but i got the wj steering for that - wouldn't mind seeing some closeups of the heims. Also, did you drill out the knuckles for the heim bolts and what did you use (tube, heims, bolts and nuts)? and were there any issues with hitting the diff cover?
Logged
neale_rs
Member
Offline Offline
« Reply #7 on: May 26, 2010, 10:38:25 AM »
I like the fact that you were able to put the tie rod ends on top of the steering arms as well as have the high steer.  I´m not sure the Teraflex high steer kit would have enough space to put the tie rod over the arms on the passenger side ... at least I've never seen one set up that way.
Logged
andrew383
Member
Offline Offline
« Reply #8 on: May 27, 2010, 07:37:16 PM »
Ill get some pics this weekend for ya..Honestly id have to go out and look at everything again to see what size it is lol...
The only problems i had were the swaybar tabs so we put a bend in the tube out by the knuckles and i cut the tabs off
 naughty
Looking at the TF kit you maybe able to fit the TRE on the top,but for that price id just go and find the steering off a wj in the junk yard and save $$$..
« Last Edit: May 27, 2010, 07:38:39 PM by andrew383 » Logged
97 tj 2.5 5sp
TrailsLessTaken
Assistant Squirrel Inspector®
Member
Offline Offline
Bail Out Willys
WWW
« Reply #9 on: June 26, 2010, 07:06:39 AM »
Where were your pics taken at?
Logged
- Bob
JP Frog Offroaders - Live in central Indiana and looking for a club? Come check us out www.jpfrog.org or meetings are first Thursday every month, 7pm at Fox and the Hound in Carmel
stan98tj
Empty Wallet Wheeling Since 2007®
Member
Offline Offline
Wheeling CT/Long Island
« Reply #10 on: June 27, 2010, 04:36:41 PM »
What kind of lift is that? what brand rock sliders?
Logged
98 TJ 33"Toyo, new long block lol,RoughCountry 3.25"+1"BL,IronMan Fab control arms,4.56gears,Ford 8.8,WARN VR10,EATON front locker,Body Armor Rock Rails WISHLIST:TDi.Girlfriend hates it :) If you can read this don't flip me over i dont have any $$ left to fix it
knotts89
Member
Offline Offline
« Reply #11 on: September 02, 2010, 11:23:20 PM »
did anyone ever figure out what lift  he was running. Looking to lift my tj that height soon and was very impressed with the flex some info would be great
Logged
98 tj 4.88 gears, 4.0 tb, tb spacer, air raid intake, mbrp exhaust, 4 inch lift and some 33s
Mozman68
Poseur Extraordinaire®
Member
Offline Offline
« Reply #12 on: September 03, 2010, 11:54:55 AM »
Looks like a standard off-the-shelf 3" suspension lift (coils, shocks, disconnects, trackbar relocation bracket, etc.)
Logged
2000 TJ...4" Full Traction long arm, ORO swayloc, HP D60's front and rear, 35x12.5 Trxus MT's on 17x9 AR Teflon Chambers, Hunsaker front seats, ARB lockers front and rear, JCR off road flat fenders, sliders, rear fenders installed over PSC crusher corners
stan98tj
Member
Offline Offline
« Reply #13 on: September 04, 2010, 05:01:22 PM »
looks like it's a rough country kit. not sure what size. could be anywhere from 2.5"-3.75"
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
SMF Theme © Gaia
Valid XHTML 1.0! Valid CSS!
