4bangerJP.com
May 23, 2012, 03:17:12 PM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News: Read the FAQ.                                      ...Everybody's Doing It!                                  ...Except you!
   Home   Help Login Register
Pages: [1]   Go Down
  Print
Author Topic: my other 4banger 4wd  (Read 1819 times)
Quyjeeper
Guest
« on: June 27, 2010, 01:12:53 PM »
93 subaru wagon 5 spd
[attachment deleted by admin]
Logged
4BangerJP.comŽ Donator
Member
Offline Offline
« Reply #1 on: June 27, 2010, 02:20:21 PM »
needs a lift kit and 31's lol
Logged
Jeffy
#1 FanŽ
Member
Offline Offline
« Reply #2 on: June 27, 2010, 06:33:52 PM »
Unless it has a 2-speed transfer case it should be called AWD.
I kind of like lifted Outback Legacy's.
Logged
Youtube Channel: http://www.youtube.com/user/4bangerjp
"If the motor car were invented today, there is absolutely no way that any government in the world would let normal members of the public drive one." -Jeremy Clarkson
sharpxmen
Chief Squirrel BlowerŽ
Member
Offline Offline
« Reply #3 on: June 27, 2010, 07:12:16 PM »
i had 3 subarus in the past, 2 of them were 4wd hi only (one lever one button actuated) and one was 4wd hi/lo lever actuated (this one was a frankenstein, bought the motor which was a turbo and transmission second hand, original tranny was 2wd/4wd hi only). neither one was AWD and were 2wd permanent with 4wd on demand (no diff between axles).
not sure if his is awd or not, mine were 80s and early 90s models so things could've chaged since.
Logged
Tsd
Member
Offline Offline
« Reply #4 on: June 27, 2010, 11:18:34 PM »
Those Subaru´s are as fast as hell, my mom has a 94 legacy automatic. I'm used to the Jeep on-off accelerator so when I have to take the Subaru i have to be really careful not to do 55 in the city.
« Last Edit: June 27, 2010, 11:19:00 PM by Tsd » Logged
Not all those who wander are lost
sbsg2005
Guest
« Reply #5 on: September 30, 2010, 07:27:03 PM »
im thinkin waggy 44s  and 35s with a tranny swap and hi/lo case id wheel the heck out of it. eh actually id take to the bird now gotta find the weak links first.
Logged
stan98tj
Empty Wallet Wheeling Since 2007Ž
Member
Offline Offline
Wheeling CT/Long Island
« Reply #6 on: December 04, 2010, 08:42:13 PM »
my girlfriend used to have an 03 suburau wagon with the auto box. i too used to have to be careful when driving it. you would be well over 70 before you knew it.
Logged
98 TJ 33"Toyo, new long block lol,RoughCountry 3.25"+1"BL,IronMan Fab control arms,4.56gears,Ford 8.8,WARN VR10,EATON front locker,Body Armor Rock Rails WISHLIST:TDi.Girlfriend hates it :) If you can read this don't flip me over i dont have any $$ left to fix it
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
SMF Theme © Gaia
Valid XHTML 1.0! Valid CSS!
