4bangerJP.com
May 23, 2012, 04:04:39 PM *
News: Did You read the FAQ?        ...most likely not...        ...why not try it?
   Home   Help Login Register
Pages: [1] 2   Go Down
  Print
Author Topic: Syncromesh vs. Mt-90 for AX5  (Read 1355 times)
RT
Member
Offline Offline
« on: September 07, 2010, 04:29:45 PM »
Which one of these gear oils protects your tranny better?
Logged
2000 Jeep TJ, Cold Air-Ram Intake, Flowmaster 40 w/ 2.5" pipe, Rubicon Alloys, 285/75/16 Wrangler MTR kevlars. Rancho RS5000's (to come), RS9000 steering stabilizer. Full Synthetics.
jfrabat
Gargantuan Mango Tree Mechanic®
Member
Offline Offline
Finally USING the Jeep!
« Reply #1 on: September 07, 2010, 05:37:46 PM »
I have not run Synchromesh, but MT90 is great; it made my tranny smoother.
Logged
FourbangerYJ
Servicing Squirrels Since 1995®
Member
Offline Offline
« Reply #2 on: September 07, 2010, 06:38:24 PM »
Me too.
Logged
Using tools you have not used in a while is like shaking hands with old friends. nod
Bounty Hunter
Member
Offline Offline
WWW
« Reply #3 on: September 07, 2010, 08:03:11 PM »
Is synchromesh a synthetic like the MT90?
Logged
chrisfranklin
4BangerJP.com® Donator
Member
Offline Offline
« Reply #4 on: September 07, 2010, 08:08:11 PM »
Mt-90 is what I'm using and it's good.
Logged
'94 2.5 YJ S 5spd, Borla Cat-Back, CarSound Cat, Ceram. Headers, PDI Ignition, 62mm TB, Airraid intake, 19lb injectors, Sharp's Adjust. FPR, MeanGreen Starter, 210 amp alternator, D30 Aussie, 31" Destination MTs, bunch of armor.
dwtaylorpdx
Member
Offline Offline
« Reply #5 on: September 07, 2010, 08:30:08 PM »
Guess I'm the odd man out, but my tranny was rebuilt to use lighter weight lube,
the stock bearings are shrouded and if the lube is too thick it wont get in the
bearings like its supposed to. (Yet another Mopar spec against what Aisin recomended....)
I've been running 20W50 Synthetic oil. Or The actual AX5 lube from the dealer.
The real test would be a temperature probe and some freeway miles... HMM>
Logged
94 YJ - 2.5 Hesco Cam B&B Ported - AX5 Trans w/Centerforce Dual Friction Clutch - 4" Rough Country Lift W/Black Diamond Shocks - D44 Rear w/ARB - D30 Front W/ARB - Homebuild on board electric air - Warn M8000 in Custom Bumper - Reunell Rear Bumper - Tuffy Console & Cargo - 265x85-16 Tires - 2M Radio
neale_rs
Member
Offline Offline
« Reply #6 on: September 08, 2010, 06:35:26 AM »
I've been using Pennzoil Synchromesh for about 4 years now  (only about 5000 miles) and it has worked well.  I don't think it is synthetic and it was available locally.
Logged
RT
Member
Offline Offline
« Reply #7 on: September 08, 2010, 09:20:31 AM »
kk I just ordered some, shits expensive!! fitz but less expensive than a tranny i guess.
Logged
aka-justin
Valve Stem Saftey Inspector®
Member
Offline Offline
« Reply #8 on: September 08, 2010, 10:48:19 PM »
I'm running mobil's synthetic gear oil in my AX-5, Mobil 1 Synthetic Gear Lube
LS 75W-90, seems ok, but not real happy with my shifting.  Seems to have gotten tougher.  First chance I'm switching to some standard gear oil or MT-90.
« Last Edit: September 08, 2010, 10:55:37 PM by 1995yj » Logged
[2003 TJ Rubicon 4.0L with 4" lift on 35" Wrangler M/T]
Bounty Hunter
Member
Offline Offline
WWW
« Reply #9 on: September 09, 2010, 05:30:03 AM »
Mobil is likely GL5 and will ruin your synchros, causing notchy shifting before it gets real bad.  Change it to synchromesh or MT90 soon.  MT90 is best, being a full synthetic it can really improve the shifting, especially when cold.
Logged
jfrabat
Member
Offline Offline
« Reply #10 on: September 09, 2010, 07:53:59 AM »
I'll second this; I had strong doubts when I bought it (was thinking along the lines of "snake oil"), but mine shifts real nice now.
Logged
FourbangerYJ
Member
Offline Offline
« Reply #11 on: September 09, 2010, 08:28:02 AM »
I ran M1 for about 10K miles. I changed it out and was very surprised to see how much shiney yellow syncro material came out with it. M1 is a GL5 lube. That's bad MMkay. Standard gear oil is GL5, that's bad MMkay. Syncromesh or Redline MT90 or one of the other oils listed in the FAQ page is what you need. (GL3) rated.
Logged
RT
Member
Offline Offline
« Reply #12 on: September 09, 2010, 05:20:37 PM »
Sweet, whatever works man, will I feel any difference in acceleration or overall peppyness. weee..seeing as how I'm lessing the friction lag on my engine
Logged
FourbangerYJ
Member
Offline Offline
« Reply #13 on: September 09, 2010, 05:40:23 PM »
I didn't. But now I need only a few hours of sleep each night and my vision is much better  wall  eek
Logged
RT
Member
Offline Offline
« Reply #14 on: September 09, 2010, 06:32:07 PM »
bandit
Logged
Pages: [1] 2   Go Up
  Print
Jump to:
SMF Theme © Gaia
Valid XHTML 1.0! Valid CSS!
