JohnnyO
Member
Offline
« on: April 23, 2011, 07:37:22 AM » |
Put an Airaid intake on today.
Logged
Steeler Nation does not have to travel. We're already there.
JohnnyO
Member
Offline
« Reply #1 on: April 23, 2011, 01:17:05 PM » |
Scrounged up a set of factory aluminum wheels on eBay a few weeks ago too.
Logged
sharpxmen
Chief Squirrel BlowerŽ
Member
Online
« Reply #2 on: April 23, 2011, 07:00:54 PM » |
Put an Airaid intake on today.  you're sure this screen is installed correctly, should isolate the filter from the engine bay so it won't suck in hot air. Filter is massive though
Logged
JohnnyO
Member
Offline
« Reply #3 on: April 24, 2011, 04:59:29 AM » |
Yup, it's bolted up exactly to the fender holes where it's supposed to. The other side that you can't see is totally covered. The stock intake gets it's air from underhood air too though. It's good for fording water, low restriction....not so much.
Logged
95yjman
Member
Offline
Phat YJ
« Reply #4 on: April 26, 2011, 09:29:32 PM » |
I like the 4 banger sticker, I need to pick me up a set heh
Logged
Trail Jeep: 95 YJ, 33's, 4:88's, spooled D44 rear, BDS Lift
Baby Jeep: 04 KJ, mopar skid plates, front tow hooks
Daily Driver/tow rig: 2005 Ford F-350
JohnnyO
Member
Offline
« Reply #5 on: April 27, 2011, 05:19:45 AM » |
The Jeep is my daughter's ride. Her nickname for years has been Squirrel, so it was kind of a no-brainer.
Logged
knotts89
Member
Offline
« Reply #6 on: April 27, 2011, 06:44:20 PM » |
a little curious about the shield myself. I have the full airaid intake and my shield goesmaround the back and side and seams to seal pretty good too
Logged
98 tj 4.88 gears, 4.0 tb, tb spacer, air raid intake, mbrp exhaust, 4 inch lift and some 33s
sharpxmen
Member
Online
« Reply #7 on: April 27, 2011, 09:16:29 PM » |
Yeah, that's what i thought is supposed to look like - can you post a picture of yours installed?
Logged
knotts89
Member
Offline
« Reply #8 on: May 01, 2011, 07:46:58 PM » |
Here is wat mine looks like
« Last Edit: May 01, 2011, 09:14:10 PM by Jeffy »
Logged
JohnnyO
Member
Offline
« Reply #9 on: May 03, 2011, 06:33:17 PM » |
They did list two different applications, one looked like it had a longer tube that ran all the way to the TB, maybe that's what knotts89 has. Mine has the shorter tube that connects to the factory plenum but it cost about $50 less.
Logged
sharpxmen
Member
Online
« Reply #10 on: May 03, 2011, 10:14:05 PM » |
well, that missing screen is quite important though - otherwise is really no different than sourcing a pipe and a filter.
Logged
JohnnyO
Member
Offline
« Reply #11 on: May 04, 2011, 07:40:13 AM » |
The filter is totally covered on the side facing the motor. But like I said, the stock intake wasn't cold air either, it's going to suck underhood air too (but it's damn restrictive). As far as I can tell, the only way to get a cold air intake on a Jeep is with a snorkel. For example my Sport Trac has a sealed airbox from the factory with a ram tube that runs out next to the headlight. Lotta dudes on the Sport Trac boards ask about getting a CAI without realizing that it already has one.
Logged
sharpxmen
Member
Online
« Reply #12 on: May 04, 2011, 07:56:48 AM » |
YJ supposedly has the same thing, on mine was missing though. not sure about TJ.
Logged
JohnnyO
Member
Offline
« Reply #13 on: May 04, 2011, 08:17:33 AM » |
The OE airbox on mine had a horn shaped intake tube that sticks straight up from the top cover.
Logged
Jeffy
#1 FanŽ
Member
Offline
« Reply #14 on: May 04, 2011, 11:40:29 AM » |
You can always add some ducting and a scoop kind of like a Oldsmobile RamAir. Then remove it when you know it's gonna suck up water.
Logged
