4BangerJP.com
September 09, 2010, 02:22:13 PM *
Did you miss your activation email?
News: You didn't read the FAQ did you?                                      ...Why not check it out?
   Home   Help Search Login Register
Pages: [1] 2 3 ... 10
 1
 on: Today at 01:23:27 PM
Started by Mozman68 - Last post by Jeffy
You could probably fit a backing plate on there and just cut it out for the caliper.  That's how the OEM ones are done.
 2
 on: Today at 01:16:07 PM
Started by FourbangerYJ - Last post by Jeffy
Pretty cool.  At the end it looks like they avoid turning the tires too much or maybe they are limited by something.
Turning the wheels puts a lot of lateral stress on the lugs.  So if your  lugs are hand tight it will cause them to loosen up.  Although, if they're tearing it down every 100yrds it won't matter much.
 3
 on: Today at 01:00:52 PM
Started by FourbangerYJ - Last post by FourbangerYJ
Limited to having it fall apart  lol There was not much holding it together.
 4
 on: Today at 12:52:35 PM
Started by FourbangerYJ - Last post by neale_rs
 5
 on: Today at 12:46:11 PM
Cool, but I agree.  Everything is made to come off.  The hood had dosconnects and there were no inner fenders, no glass, etc...  The body is just sitting on some mounts.  No front driveshaft and the rear has some sort of simple setup that doesn't need bolts.  No transfer case either.  Notice, there is no gas tank and no coolant in the radiator.
I think they should use a barn find CJ-5 and try it again.  I'm sure it will take a bit longer.  lol
 6
 on: Today at 12:20:42 PM
<a href="http://www.youtube.com/v/gD78rTF0Rjo?fs" target="_blank">http://www.youtube.com/v/gD78rTF0Rjo?fs</a>
Not sure I would take it on a long trip or go wheeling with it the way they have everything finger tight. But pretty cool.
 7
 on: Today at 08:55:45 AM
Started by derekr - Last post by FourbangerYJ
we all do as we get older  guns
3700 is not bad at all, was that with the driver in it? lol
 nod I am only 180#  spam
 8
 on: Today at 08:41:34 AM
Started by jagular7 - Last post by sharpxmen
I have seen a luggage trailer in airport. They used this trailer to get the luggage of passengers. This is a nice trailer because as a passenger, you are not going to carry your luggage. But I have searched that even in a trip, this luggage trailer will change the way you road-trip and enjoy the outdoors, and will give you that extra space you so often need with a small car.
it's nice to see some thoughtful posts here for a change  wall
 9
 on: Today at 08:38:18 AM
Started by derekr - Last post by sharpxmen
Last time I weighed mine it was around 3700 IIRC. (not loaded down for a run but the tank was full)  twofingers That was a long time ago. I might have to hit the scales again. I would think she has gained weight over the years.
 10
 on: Today at 08:31:11 AM
SMF Theme © Gaia
Valid XHTML 1.0! Valid CSS!
