61
The Mess Hall / Re: Which Atlas Transfer Case
« Last post by FourbangerYJ on August 21, 2020, 10:11:43 PM »So that puts you at 84:1 with just the 4:1. That seems to be the golden number for the Rubicon. The TJ Rubicon who was with me was pretty much stock on the same tires and was 65:1 but I know that's not going to be low enough for a 2.5L. An AX-5 and a 4.3 would already be 86:1.
I'm curious to know how much you use 2nd and 3rd with any combination though... I just realized you're running 2.46 and 2.72 not 2.46 and 4:1. That's huge overlap then. So really you're only using or 2.72 or both.
I'd kinda like to keep it simple so that's why I'm consider a 2-speed over a 4-speed. I'm sure if I ever do an engine swap 5:1 will be too low... Gonna have to look at all the numbers again
I use 2nd and 3rd gear a lot when I had the 4:1. Now with the 2:7 Im sure I'll be using both boxes in low and rowing between the gears in the transmission up to 3rd gear.
