Author Topic: Body bushing kit with hardware?  (Read 651 times)
« on: October 21, 2014, 03:09:32 PM »
I'm looking for a body bushing kit for my YJ that comes with hardware.  All of the ones that I've seen that are 0" lift don't come with any hardware.  Anyone just sell the hardware or am I gonna have to buy them separately?  The sleeves would be the only problem area.  Would be nice to get a body bushing kit with hardware though.
Re: Body bushing kit with hardware?
« Reply #1 on: October 21, 2014, 06:36:28 PM »
I'm also looking for a 0" lift kit with the sleeves included.  Hopefully someone knows.
'95 YJ, 33 x 12.5 BFG MTs, RE 4.5 ED lift, Atlas 4 speed, rear D44, ARBs front and rear, 4.56 gears, 8000# winch
« Reply #2 on: October 21, 2014, 11:08:58 PM »
I haven't been able to find one.  Since I'm going form 1" to 0" I need al new bolts.  My OEM's were eaten up really bad which was a good enough reason to replace them.  I saw Crown sells OEM rubber mounts with those 'mushroom' sleeves but I don't think my Jeep ever had them.  I could probably salvage my sleeves but if I can I'd like to replace them.  I had to cut a sleeve to rebuild the front mount since it was really rusted bad.  I don't get why they make all new hardware for 1" but have you reuse all of it for 0".  I could see it being cheaper but for the majoriety of the people who are going to bother to swap the mounts, their hardware is in bad shape.
« Reply #3 on: October 24, 2014, 09:11:01 AM »
That CROWN set you mention sounds good.  Thanks.
« Reply #4 on: October 24, 2014, 03:37:09 PM »
This is the kit.  http://www.amazon.com/Crown-Automotive-52002723K-Body-Mounting/dp/B008VPVF82/ref=sr_1_1?ie=UTF8&qid=1414186718&sr=8-1&keywords=crown+body+mounts+52002723K
No washers or bolts but that's not the harder to get part.  Though you can make sleeves front tube steel and cut down sections to match.
« Last Edit: October 24, 2014, 03:39:00 PM by Jeffy »
« Reply #6 on: October 24, 2014, 04:14:40 PM »
Looks like you could also get 6 of these: http://www.crownautomotive.net/product/YJ-Body-Parts/52001961.html - http://www.summitracing.com/parts/cwa-52001961
And 4 of these: http://www.crownautomotive.net/product/YJ-Body-Parts/52002661.html - http://www.summitracing.com/parts/cwa-52002661
That's $49.70 from Summit Racing.  Then you have $40.97 for the 10 - washers http://www.summitracing.com/parts/omx-1221703.  That's not including the grill support or the bushings nore the 10 bolts for the body.
Things start to get really expensive.
« Last Edit: October 24, 2014, 04:34:17 PM by Jeffy »
Offline grumpygy
« Reply #7 on: October 24, 2014, 07:23:51 PM »
  Best way to do it is pull the bolts you need and go to a place Like Fastenal or like I have here Eugene Fastener.  A place dedicated to fasteners.  They will be much cheaper.
Here is a place I use daily to look up parts.
http://www.mcmaster.com/#
« Reply #8 on: November 12, 2014, 04:34:31 PM »
I ended up changing my mind about removing the body lift.  It would be too much of a PITA.  I'd then have to remove my 1" MM lift as well.  Also the additional clearance would give me more room for any drivetrain swaps that may not be planned.
