Author Topic: 2.5/2.9L Strokers  (Read 612 times)
2.5/2.9L Strokers
« on: January 13, 2017, 02:07:44 PM »
http://www.shop.505performance.com/category.sc?categoryId=40
Looks like 505 Performance has stroker kits.  They have full cams, cranks, rods, heads etc...
"4340 H beam rods, Forged custom piston 8.75 to 10.75. Stroker crankshaft Select bore 3.945 or 3.960 Performance gaskets, oil pump, injectors 24lb stage 1 2 3 race cam lifters springs 4340 timming set 45 percent more hp 55 percent more torque. Most kits will ship in 5 to 10 days"
HD Head
"New heavy duty 2.5 jeep head  stainless 2.0 intake 1.570 exhaust stainless valves cnc 5 angle valve job 4340 spring retianer keepers good for .500 lift and all hydralic cams 15 hp upgrade intake 1.570 exhaust stainless valves cnc 5 angle valve job 4340 spring retianer keepers good for .500 lift and all hydralic cams 15 hp upgrade."
Pro-Rock Head
"NEW HD HEAVY DUTY fully ported cylinder head 2.00 intake and 1.570 exhaust valves Chrome molly spring retainer keepers .580 max lift hydraulic and solid cams compatible. Raised exhaust runners and profiled intake runners flowing over 280 at .500 lift on intake side and 180 plus exhaust.SHIPPING CONTINENTAL USA $40.00 FED EX"
Adjustable and non-adjustable rockers
"Jeep 2.5 AMC 4cyl non adjustable Roller Rockers
1.62 ratio
Non-adjustable roller rockers pedestal mount
12hp gain
Direct bolt on no machine work needed.
Requires 2 valve cover gaskets to clear."
