Author Topic: Humming Noise When I Let Off the Gas  (Read 1986 times)
Offline DanMarino
Re: Humming Noise When I Let Off the Gas
« Reply #30 on: July 18, 2017, 06:31:40 AM »
Was able to extract the broken rear differential cover bolt that I snapped the head off of.
Jacked the rear end of the YJ up in the air and secured with jack stands.
Lowered the rear axle so that I  had just enough clearance to work on the broken bolt without interference from the fuel tank and skid plate.
Tried to center punch the broken bolt to make a place to start my drill.
Used a small left hand drill bit to drill through the center of the bolt.
Sprayed a bunch of WD40 as I was drilling.
Used a larger diameter left hand drill and expanded the hole in the bolt.
The bolt remnants gripped onto the drill bit spun out smooth as butter.
Threads seem fine.  Just need to get a new bolt.   :biggrin:
Still some noise when I drive and let off the gas.  Not sure where it comes from.
Offline bootguy
« Reply #31 on: July 18, 2017, 08:01:01 PM »
Could it be the 2 piece front drive shaft not disengaging and you hear the drive line operating the transfer case?
Offline DanMarino
« Reply #32 on: July 19, 2017, 07:07:10 AM »
Thanks Bootguy, how would I check this?
The front drive shaft should not be spinning when in 2 Hi, right?
Offline DanMarino
« Reply #33 on: July 19, 2017, 11:32:01 AM »
Stuff I'm reading sounds like if there is noise/humming when decelerating, then it is an issue with the pinion bearings.
Offline bootguy
« Reply #34 on: July 21, 2017, 07:34:49 PM »
Put it up on jacks and turn the right front tire.  If your driveshaft turns the axle is not disengaging.
