Author Topic: Guardian7 TBI Spacer Project  (Read 3091 times)
« Reply #15 on: October 10, 2006, 01:15:04 PM »
I'll give this a bump so you everyone sees this.  You got your own thread now. :thumb:
TURBOD16V
« Reply #16 on: October 10, 2006, 02:11:53 PM »
Thanks!
I was wandering guardian what have been your impressions so far on the test spacer?
 thanks again
Guardian7
« Reply #17 on: October 10, 2006, 10:52:19 PM »
Status as of 10/10/06, headed over to the machine shop Friday and pulled the spacer out to change the bore size. While we had it all torn apart we made some precise measurements on the inake and throttle body bore diameters. We then proceeded with making the changes to the drawing in solidWorks, created some new CNC code and reworked the spacer. I have now been running it about 4 days and can feel a bit more midrange power from the spacer mods which now has the bore matched to both Intake and Throttle body openings. The intake opening diameter was larger than the throttle body diameter so there is a nice outward taper to the spacer bore. At this point I dont feel inclined to do much more on it and need to decide if we want to run a small quantity of units for others to try.
TURBOD16V
« Reply #18 on: October 11, 2006, 06:45:33 AM »
I'm game!  :D
 let me know what you need.
« Reply #19 on: October 11, 2006, 07:02:32 PM »
are you realy just not inclined to do more or is it that you jsut bought an new jeep :stick: lol.. jk... i think id be up for this spacer if you made osme..
Guardian7
« Reply #20 on: October 14, 2006, 01:03:17 AM »
Have you any suggestions on further mods or tests I can do which wont cost me alot of money?
« Reply #21 on: October 14, 2006, 12:44:33 PM »
I would just keep the spacer simple and use a straight bore.  Not much else other then maybe adding a larger TB or maybe cnverting to a modern coil would be exclusive to a TBI.
Guardian7
« Reply #22 on: October 15, 2006, 10:31:13 AM »
That is basicaly what we have, since I am matching the spacer bores to the intake and TB there is a slight taper because the bore size of the intake is slightly larger and I did not want a lip for airflow to hit.
Got Wood?
« Reply #23 on: October 18, 2006, 01:19:25 PM »
would it be possible to make an adaptor that would accomodate a different or maybe larger tb?
TURBOD16V
« Reply #24 on: October 30, 2006, 07:01:35 AM »
BUMP!! :D
Guardian7
« Reply #25 on: October 31, 2006, 12:10:30 AM »
An adapter could easily be made but you may want to open the bore on the intake manifold to prevent restriction. I have thought about making an adapter which would allow mounting a post 91 TB to the pre 91 intake but more research would be needed.
« Reply #26 on: October 31, 2006, 10:40:40 AM »
Quote from: "Guardian7"
A lot more research would be needed.  Remember the pre-91's are TBI and not MPFI.  If you really want to go MPFI, you could swap intakes and do the whole fuel rail, PCM, harnesses, the works to convert it.  Otherwise, you'll end up with a MPFI TB and no way to get gas into the engine.
Guardian7
« Reply #27 on: November 02, 2006, 10:15:13 PM »
That is a problem!
Got Wood?
Re: Guardian7 TBI Spacer Project
« Reply #28 on: February 12, 2007, 02:13:22 PM »
[/quote/]
Make one and sell it to me and I will gladly be your spokesman.
« Last Edit: February 12, 2007, 02:14:56 PM by Got Wood? »
dudley
« Reply #29 on: June 10, 2008, 07:11:32 AM »
My 87 is drooling over the possibility of a spacer.  How is it going?
