Author Topic: Mopar Performance Parts List  (Read 10278 times)
admin
« on: May 25, 2005, 01:09:46 PM »
Main Bearings
                      P4529648     Standard
                 P4529649     .001 Undersized
                 P4529650     .002 Undersized
Connecting Rods
       P4529209     2.5L & 4.0L
Connecting Rod Bolts
  P4529816     2.5L & 4.0L
Connecting Rods
       P4529208     Standard
                 P4529236     .001 Undersized
                 P4529238     .010 Undersize
Pistons 2.5L & 4.0L
                 P4529210     .010 Oversized
                 P5249902     .030 Oversized
                 P5249903     .060 Oversized
Rings
                 P4529652     .010 Oversized (2.5L only)
Roller Time Chain & Sprocket Set
                      P5249519     2.5L & 4.0L
Timing Chain & Sprocket Package
                      P4529822     2.5L
Gear Drive
            P5249009     4.0L (Should work for 2.5L)
Engine Gasket Set
     P4529665
Teardown - for 2.5L
Oil Pan Gasket
        P4529664     2.5L
2.5L High Performance Crank
                      P4529646     HP Crank 2.5L (Offroad only)
Vibrations Damper
     P4529669     Replacement 2.5L
Damper Attachment Package
                      P4529677     2.5L & 4.0L
Camshafts:
                      P4529656
Factory Engineered Hydraulic Cam and Tappet Package for Mild Competition Application 240-240-24* Duration, .430" Valve Lift, 108 Centerline
                      P4529657
Factory Engineered Hydraulic Cam and Tappet Package for Mild Competition Application 248-248-32* Duration, .440" Valve Lift, 108* Centerline
                      P4529658
Factory Engineered Hydraulic Cam and Tappet Package for Mild Competition Application 256-256-40* Duration, .450" Valve Lift, 108* Centerline
                      P4529659
Factory Engineered Hydraulic Cam and Tappet Package for Mild Competition Application 260-260-44* Duration, .460" Valve Lift, 108* Centerline
                      P4529660
Factory Engineered Hydraulic Cam and Tappet Package for Mild Competition Application 268-268-52* Duration, .480* Valve Lift, 108* Centerline
Tappet
                P4529220     Hydraulic Tappet
Push Rods
             P4529654     Standard Length
                      P4529219     Standard Length (Hydraulic)
Push Rod Package (Sets)
                      P4529674     Standard Length (8)
Race Prepared Head
    P4529644     Mildly Ported Cylinder Head Assembly
Head Bolt Set
         P4529645     Head Bolt Set (11)
Manifold Attaching Package
                      P4529679
Intake/Exhaust Manifold Package:
Valves
                      P4529212 Standard Diameter Intake Valve -Backcut - 2.5L & 4.0L
                 P4529213 Standard Diameter Exhaust Valve - Backcut -2.5L & 4.0L
                      P5249879 1.50" O.D. Exhaust Valve -5/16" Stem (Stainless)
                 P5249880 1.56" O.D. Exhuast Valve -5/16" Stem (Stainless)
Valve Seals
          P4529661     Valve Seal Package (8)
Valve Spring
                      P4529214     Cylinderical
                 P4529215     Conical
Spring retainers
                     P4529216 Cylinderical Valve Spring
                     P4529217 Conical Valve Spring
Rocker Arms
                 P4529221     Stamped
                 P452988      Roller Rocker Set (Must use spacer for valve cover clearance) -4.0L
Head Gasket
           P4529662
Intake/Exhaust Gasket
                      P4529663     2.5L
High Performance Air Filter
                      P5249918     K&N Filter
Exhuast Gasket
        P4876110
Clutch Disc & Pressure Plate Set
                      P5249406     Centerforce Gold
2.5L Jeep Inline 4 Engine
Stage I Engine Package A
    * Set timing for Maximum HP
    * HP Hydraulic Cam 240" or 248" P4529656-657
    * Valve Seal Package P4529661
    * Valve Spring - Conical P4529217
    * Conical Retainer- P4529217
    * Low Restriction Enhaust
    * Estimated 10 to 20 hp gain over stock
Stage II Engine Package B
Same as Engine Package A except for the following items:
    * HP Hydraulic Cam 256" or 260" P4529658-659
    * Centerline Cam with Bushing Kit P3690936
    * Backcut Valves P4529212-213
    * Richen Carb
    * Engine oil Cooler P45292690
    * Headers
    * Estimate 20 to 30 hp gain over Stage I
Stage III Engine Package C
Same as Engine Package A and B except for the following items:
    * Increase C.R.
    * HP Hydraulic Cam 268" P4529660
    * Ported Head P4529644
    * Intake Manifold Attaching Package P4529679
    * Good Gas
    * HD Rod Bolt and Nut Package P4529817
    * Estimated 20 to 30 hp gain over Stage II
