Author Topic: Future Floor Wax as an Automotive Paint Protectant/Restorer  (Read 13678 times)
« Reply #30 on: September 18, 2006, 12:48:04 AM »
Only huge mistake made while buffing is heat. As long as you keep feeling the hood while you do it and not concentrate on one spot you should be fine. Keep the paper good and wet while sanding and keep that buffer moving and you should be fine. If you get nervous about burning through the paint you can also turn down the speed. It'll just take longer.
Guardian7
« Reply #31 on: September 20, 2006, 08:18:01 PM »
Jesse, your advise is encouraging and I may decide to get brave and give it a try, I'll let you know.
