General Forums => The Mess Hall => Topic started by: RockyMtnYJ on March 08, 2006, 01:25:54 AM
Title: TB Swap - Quick Question
Post by: RockyMtnYJ on March 08, 2006, 01:25:54 AM
I just learned that I can get my mittens on a '97 4.0 TB.  Will this TB work on my 95 2.5 YJ?  Do I need to grab anything else off the '97 besides the TB itself?  Thanks!
Post by: yellowta on March 08, 2006, 07:01:29 AM
Your 95 will be OBD-I and have one fewer sensor on the throttle body. The 97 should work, but you will have to pull off the manifold pressure sensor on the drivers side of the throttle body and plug the vacuum line under it. Your 95 should have that sensor mounted on the intake manifold alread. You will be swapping over your old sensors on the thing anyway, so you don't have to worry about the connectors being different :wink:
