General Forums => The Mess Hall => Topic started by: Dynamic4x4 on July 22, 2011, 09:45:56 AM
Title: need help lots of codes in the pcm
Post by: Dynamic4x4 on July 22, 2011, 09:45:56 AM
I have a 95 yj that is throwing codes for lose of battery power, oxygen sensor-lean condition, fuel injection control, MAT Sensor, oxygen sensor or circuit, and engine running to cool.  i am pretty sure that the runing to cool is becouse my fan runs constantly (im stationed overseas and still need to get a thermostat and wire everything up).  The oxygen sensor is also less than 500 miles old.  Im just not sure what caused the codes battery has not been disconnected or went dead in atleast the past 2000 miles so that is confuseing aswell.  The jeep runs normal just finaly decided i should try to get the light off.  i would greatly appreciate any help or ideas on this
Title: Re: need help lots of codes in the pcm
Post by: sharpxmen on July 22, 2011, 11:27:42 AM
reset the 'puter first, then when you get the new CEL check the codes right away. These codes you're seeing could be old codes.
lean condition could mean lack of fuel pressure or an injector not firing (opening to be more specific).
Post by: Dynamic4x4 on July 22, 2011, 12:34:09 PM
thanks i will try that in the morning is there any way to reset it other than just unhooking the battery?
Post by: FourbangerYJ on July 22, 2011, 01:10:22 PM
Remove the + battery cable from the battery and hold it on the - cable for about 30 seconds.
Post by: Dynamic4x4 on July 23, 2011, 10:57:09 AM
ok i cleared out the codes and now it is just saying the code for the MAT sensor so im going to go ahead and order a new sensor but when i was looking at it i noticed the coolant sensor that is at the back of the head had broken off is this the sensor that controls the gauge?
Post by: sharpxmen on July 23, 2011, 11:29:52 AM
that's the one for the gauge, the one on the thermostat housing is for the PCM. MAT i take is manifold air temperature and would be in the manifold showhere 1/2 way on the run close to the firewall. Replace this one and then reset the 'puter again and see if you get more codes.
Post by: Dynamic4x4 on July 23, 2011, 11:50:22 AM
will do thanks for the help
Post by: Torch_Ind on July 23, 2011, 04:38:35 PM
:thumb:
