		General Forums => The Mess Hall => Topic started by: sharpxmen on September 18, 2011, 08:18:16 PM
				i need a suggestion for the rear brake flex line that goes from the frame to the axle, need one for a 4.5'' lift that has the splitter at the end, i cant' reuse the one i had as it's too short
what are you using?
thanks in advance for all suggestions.
				found one at 4wd for $42, any cheaper options that you might know would be much appreciated.
http://www.4wd.com/?t_pn=EXP7425-E
				Got my line here
http://www.quadratec.com/category/Brake+Lines+%26+Cables/109/index.htm
Not sure about the splitter.
