General Forums => The Mess Hall => Topic started by: geocachenut on March 22, 2012, 07:59:51 PM
Read some really old forums on a Cam upgrade for a 94 YJ with a 2.5. Apparantly there were three different Cam upgrade kits available right from the dealer. Not available any longer. Does anyone know of a "Performance" cam upgrade that can be done without redoing the head? :naughty:
There were actually 5 different cams available. All the cams were basically drop-in.
some require different springs,
best bet is a re-grind or i think one of the following might have a 4 cyl (can't remember which one): Clifford, Hesco or Comp Cams.
I believe it was Hesco and Clifford, at one point. I never looked a Comp Cams. I was looking into it, but never commited to it. I don't know if they still offer it or not anymore.
Comp Cams can do a Cam regrind. I have a post somewhere on here about searching for cams. Hesco was the only one I found that had a cam.
do they have blanks or use a stock one?
Check this post my info on compcams starts on page 2.
http://4bangerjp.com/forums/index.php/topic,10231.0.html
I never did go thru with getting one.
And after the this last week have decided the next thing I do is a good winch.
I have the Hesco, I like the power band a lot (I have the RVOB version) It was drop shipped form Clay Smith... I think Hesco owns the grind and Clay does the work.
What have you found that the cam does for your Jeep? Can you actually "feel" the difference? I know it's only a 4 banger, but am curious how much of a difference it really made. Havent' tore down the top end. Was it difficult?
