General Forums => The Mess Hall => Topic started by: Jeffy on November 04, 2013, 01:27:06 PM
(http://hss-prod.hss.aol.com/hss/storage/adam/9464436826fe4c83ea6387a50028b55a/AEV-RAM-628.jpg)
AEV Ram Concept Vehicle – SEMA Show 2013
The vehicle: 2014 Ram 2500 Crew Cab Diesel
The concept: Since 1997, American Expedition Vehicles has been on the cutting edge of the 4WD industry, constantly pushing the boundaries of design and innovation. AEV recognized that there is a void in the industry for customers who require a vehicle that is very capable off-road, has exceptional handling characteristics and ride quality but also has a large cargo capacity and is able to satisfy the demands of a heavy towing. AEV felt that the Ram was the ideal vehicle platform to fill this void. The AEV Ram Concept is gear toward the outdoorsman-someone who requires a capable vehicle off-road, but still requires the larger size, higher towing capacity and increased payload of a ¾ or 1-ton pickup truck. AEV set out to achieve these goals by breaking the mold of the traditional "lifted truck" methodology and utilized their engineering and design expertise to create a complete vehicle package that includes components that are designed to work in harmony with each other in both style and functionality. The result is a great looking truck with high ground clearance, a low center of gravity and superior front end protection.
AEV Ram Front Bumper
• Industry's only stamped steel, winch compatible front bumper for the Ram
• 3/16" steel construction
• Modular design to allow customers to customize the bumper to suit their individual needs and personal style preferences
• 1/4" steel winch mount accommodates 12-16.5k winches
• Heavy duty shackle mounts
• Provisions for 6.5" integrated off-road lights
• Compatible with 2010+ Ram 1500/2500/3500/4500/5500 trucks
AEV Ram Wheel
• 17X10 Ram-specific fitment
• OE-quality, A-356 cast aluminum construction
• SAE J2530 Certified
• 3,650lbs Load Rating
• Cast-in hub cover
• Recessed valve stem
AEV 3" Ram Suspension System
• Raises the vehicle 3" in the front and 2" in the rear for a level stance
• Retains OE coil springs to maintain capability
• Optimized suspension geometry for improved handling and increased roll center
• Custom-tuned shocks to improve ride quality
• High Steer Kit to correct steering geometry and provide precision steering
AEV High Clearance Fender Flares
• Provides additional clearance for larger tires with less lift-accommodates a 40" tire with only 3 inches of lift.
• Fender Flare design integrates with and compliments the AEV Premium Front Bumper for an aggressive yet refined appearance.
Looks good and it can run huge tires with very little lift.
Meh, looks like every other lifted Ram out there. They only real difference is that it'll be 3x the cost of the ones you already see ;)
what size tires does it have on as pictured?
40's. Stock on my 1/2 ton is 33, not sure what stock is on a 3/4 ton.
