General Forums => The Mess Hall => Topic started by: Wheezer on July 05, 2014, 03:40:19 PM
Has anyone done this? Can it be done? We're getting ready to hit the road and we will be flat towing the "Wheezer" behind the motorhome. When towing 4 down you have to unlock the steering column but that creates a problem in having the key in the ignition when towing. The problem arises in having to remember to pull the key out when leaving the rig. So I was thinking do you really need the column lock pin? Does it perform any function other than locking the steering column? If I remove the pin from the rack and pinion will it cause problems? Thoughts, opinions, comments?
BTW- the Wheezer is a '95 YJ with 2.5L 4cyl and 5spd, locked at both ends but the CAD is still installed.
Thanks!
Wheezer
Lock the doors and disconnect the battery? Digging into the steering column can be a real PITA. It's like taking apart a cake from the top everything has to come out before you get down far enough.
Yeah! A real pain, but I've already had it apart about 3 times (I won't go into why, it's just too painful to talk about), so I'm getting pretty good at it. I got a suggestion on another board to cut off just enough to not engage the lock ring but still engage the tube that it slides back and forth in. This sounds like a real good option, you know just in case it does provide stability to the rack.
Wheezer
I did it on a YJ a while back. I just pulled off the steering wheel, removed the lock plate and then used a cutoff wheel to cut the lock pin off - seem to remember cutting through the side of the plastic on the column to do it. In my case I did it because I was flat towing a lot and didn't want to have to leave the keys in it.
