General Forums => The Mess Hall => Topic started by: Jeffy on October 04, 2014, 04:59:59 PM
Title: Bigger Battery?
Post by: Jeffy on October 04, 2014, 04:59:59 PM
Just curious if anyone is running something larger then a Group 34.  Stock battery is a Group 58.  I'm wondering if I want to run two batteries or one larger battery.
A group 31 would be about 2" taller and 3" longer.  Not sure if it would fit in the stock tray but that's not a big deal.  Dual batteries would require a new tray as well. Seems the Group 34's are common for tractors (big rigs) so they would be easy to find, too.
Group 34
Dimensions:
Item Weight (lbs.):53
Length (in.):10.9
Width (in.):6.8
Height (in.):7.9
Power Ratings: Cold Cranking Amps (CCA at 0 deg.F):880
Reserve Capacity (RC):135 min.
Amp Hours at 20 Hour Rate:68
Group 31
Dimensions:
Item Weight (lbs.):75
Length (in.):13
Width (in.):6.8
Height (in.):9.5
Power Ratings: Cold Cranking Amps (CCA at 0 deg.F):1150
Reserve Capacity (RC):205 min.
Amp Hours at 20 Hour Rate: 205 min.
Amp Hours at 20 Hour Rate: 100
Title: Re: Bigger Battery?
Post by: BoringDave on October 08, 2014, 07:15:05 PM
Reefer to post 24 of my build thread and you will see the duel setup I made. Since that picture the batteries have been replace with duel Deka group 24 deep cycles each with 500cca. I have also installed a  Cole Hersee 200 amp continues duty relay. So I can link the batteries parrelle for charging and heavy winching. I didn't install a battery isolater because at some point I plan to install a second large frame 100+ amp alternator to that second battery along with on board welder abillity.
Post by: Jeffy on October 08, 2014, 07:59:40 PM
I'm wondering if anyone's installed one large battery instead of dual batteries though.  I know it's somewhat common swap for JK's but haven't seen it done on anything else.  The Group 31's also popular for those won mount the battery in the back.  The 31's also 25 lbs less when dual 34's.  On the downside, you don't have 24v when/if you want to run a Ready Welder or jumper stick welder.
Post by: dwtaylorpdx on October 12, 2014, 10:39:32 PM
I found a Gel battery that's a decent bit higher capacity and just fits in the factory tray, got it from battery specialties looked it up by dimensions.
Starts the engine instantly and seems ot run my winch fine , but I don't do heavy long pulls much..
Post by: Jeffy on October 13, 2014, 02:33:13 PM
From what I've read there's a battery that's a little longer but still fits in the stock tray.  I forget what group is it though.  I remember when I installyed by 800U.  You could heard teh speed difference when the starter spun up.  Though I'm thinking about using the Group 34 for more capacity.  Like camping for a week.  Then I can run a freezer/fridge aithout problem.  I also want to add a solar panel under my roof rack so I can trickle charge the battery as well.
Post by: grumpygy on November 20, 2014, 09:10:17 PM
Well My turn next.  Mine is over 5 years old and has just died from the little cold spell we just had.  Will hit Batteries plus and get the biggest one that will fit.
Post by: Mozman68 on November 21, 2014, 05:44:04 AM
Hah...same thing just happened to me.  Cold finally did it in....so, new battery for whomever buys the Jeep!
Post by: Hunter02 on November 25, 2014, 09:57:20 PM
I'd rather have two decent size batteries than one real big one. No matter how BIG your one battery is, it's still  only ONE BATTERY. I've always run two isolated batteries and have never used a power winch, just a come-a-long. jmho
Hunter
PS What the heck is a fridge? :nono:
Post by: grumpygy on November 29, 2014, 09:45:02 AM
Ordered one of these.
(http://b.cdnbrm.com/images/products/large/performance/optima_yellow_top_battery.jpg)
Post by: Jeffy on November 29, 2014, 11:08:57 AM
That's okay.  I don't need a 800U.  Optima's quality has dropped sicne they moved production to Mexico.  Although it's not as bad as it once was.  I can get a Odyssey battery through Sears just about anywhere.  Not to mention it has moce CCA's.
Post by: 95 Lowbuck on November 30, 2014, 02:49:59 PM
I bought one of these about seven years back, but without the extra terminals, still in the Jeep.
Don't use the side terminals for anything serious as they are thin metal straps connected to the main terminals.
Post by: Mozman68 on November 30, 2014, 05:00:13 PM
I went and bought the Sears Diehard Platinum this weekend to replace my Optima red top....it was then that I realized the Optima lasted more than 8 years!!!   :hitit:
Post by: Jeffy on November 30, 2014, 05:49:09 PM
Yeah the old Optima's were built really well.  I think they have one in their possession that's from the 80's.  Mine is circa 1998.
Post by: mark23 on December 02, 2014, 07:17:55 PM
My Red top has been running strong since 08, starts the jeep just fine when its -30 in northern NY.
Post by: Jeffy on December 03, 2014, 02:02:12 PM
When I need to get a new battery it will definitely be a Sears Platinum/Odyssey though.  They're easier to get a hold of and their Deep Cycle.
BTW: two batteries is 106 lbs vs 75 lbs.
Post by: BoringDave on December 05, 2014, 03:21:32 PM
Maybe that's why mine is so gutless?
Iirc when I got my 95 it had a groupe 31 in it. I remember it was big!
Post by: Jeffy on December 05, 2014, 06:30:56 PM
You'd know if you had a group 31 in there.  It won't fit on a stock tray.  It's the battery spec'ed for big rigs and tractors.
Post by: Wrench on December 21, 2014, 02:22:13 PM
When you get down to the "brass tacks" of lead-acid batteries, the ampacity is directly related to the lead and acid content, which is where the weight is.  I have seen "group 24" batteries differ in weight by a large amount, and their true amp-hour capacities are equally different.  Your 75 lbs of lead-acid battery will never be the same amp-hour rating as 106 lbs of lead-acid battery.
Deep cycle batteries are designed for slow but deep discharge and recharge.  Standard car batteries are designed for quick bursts of power, but dont like deep discharges.  Using deep cycles for a vehicle or using a car battery for deep cycles can shorten their lives.  But...if you use a pair of deep cycles in parallel, the short bursts of power are split between the two batteries and will retain their standard lifespan.
Whatever you do, dont by batteries from Walmart, unless you are willing to rely heavily on their warranty.  I own an RV Service business and I see more dead Walmart batteries than all other brands combined.
Post by: Jeffy on December 21, 2014, 07:59:51 PM
The two batteries in question are both deep-cycle/starter batteries and both are AGM's.  The question being is dual battery overkill though compared to just upgrading to a larger battery.  Ignoring the added feature of being able to weld with them.
Post by: 95 Lowbuck on December 23, 2014, 07:53:19 PM
Yellow Tops are deep cycle, and again 7 years is not too bad for a battery.
