General Forums => The Mess Hall => Topic started by: bukdwn on January 12, 2015, 08:20:58 AM
Title: 1995 yj block temp sensor (rear)
Post by: bukdwn on January 12, 2015, 08:20:58 AM
Would anybody have the part # for the rear block temp sensor.   Went to napa and they don't list it, couldn't even find the listing.       This is for a 95 YJ 2.5 .  This part is located on the driver side rear. Single wire/single pin.  All I can find is a 2pin .          I noticed the other day that the porcelain was broke and had separated.   I think this is just an over heat sensor??           Any help would be appreciated.
Title: Re: 1995 yj block temp sensor (rear)
Post by: Jeffy on January 12, 2015, 12:36:45 PM
This is the one you want. - http://www.quadratec.com/products/55122_01.htm
Coolant Temperature Sensor
For 92-95 Jeep® Wrangler YJ, Cherokee XJ & 93-96 Grand Cherokee ZJ
Quadratec Part No: 55122.01
Manufacturer Part No: 33004281
Post by: sharpxmen on January 13, 2015, 10:00:15 AM
it's in the head not the block, it is the gauge cluster water temp sender.
Post by: grumpygy on January 14, 2015, 06:20:03 AM
Its either a dealer Item or as was posted above Order online.
Post by: Jeffy on January 14, 2015, 02:04:39 PM
Typically, as an industry standard all parts for any given vehicle are available 10-11 years after the production line ends.  After that, it's a special order and usually from a third party.  In this case, Jeep sold all their OEM parts supply to Omix-Ada and Crown Automotive.  Both companies have continued connections with the companies who originally made the parts so they're as close to OEM as you're going to get.
Post by: sharpxmen on January 16, 2015, 11:10:19 PM
you can use an autometer temp gauge sender if you can't find an OEM one, it's a little bit off but not by much. They have a short version as well, I can't remember which one I used on mine (short or long) but before that I had the stock sender with the autometer gauge and worked ok, like I said a bit off on reading but would work.
