General Forums => The Mess Hall => Topic started by: RNandKT on July 01, 2015, 09:07:03 AM
Title: 2.5 Block Differences
Post by: RNandKT on July 01, 2015, 09:07:03 AM
OK I did some searching and I was unable to find a clear answer to this.
I picked up another 97 TJ (will be my sons Jeep) with a blow 2.5 (hole in the side of the block). I was given a donor motor from a YJ (I think it was a 94) and we are going to use that to rebuild.
So I know the head is ever so slightly different and we can use the head from the TJ so not worried about that, but when I look up rebuild kits it wants me to specify year. Are there any short block differences between the YJ and TJ 2.5's? We will reuse all the externals from the TJ motor, so my only concern is the short block. Anyone know on this.
Title: Re: 2.5 Block Differences
Post by: RNandKT on July 01, 2015, 09:47:58 AM
Oh and another side Question, has anyone ever put the famous Mopar Purple CAM in a Fuel Injected TJ/YJ? I have a lead on a purple CAM kit (Camshaft lifters springs etc) but not sure it is compatible with the fuel injection system.
Post by: Jeffy on July 01, 2015, 02:21:28 PM
I don't believe there are any major differences between the blocks...
There are many who have installed the Mopar cams.  I was even going to till I moved to a emission controlled state.  The cams were designed to be used in late TBI's and early MPFI engines.  Jeep Motorsports was involved in SCORE and SCCA events back in the 80's and early 90's.
Post by: RNandKT on July 01, 2015, 03:24:12 PM
Thanks
The guy selling the Mopar Purple CAM is selling it for $250 for the kit (CAM lifters spings etc) which since my 14 year old son has to come up with half the money of anything we put into it seems steep to him. So not sure if it is worth the money. If it isn't a really noticable difference than $250 goes a long way towards lift or other items.
Post by: Jeffy on July 01, 2015, 06:40:40 PM
Thanks
Well, there are 5 different cam profiles, IIRC.  So it really depends on which cam it is.  You can see the different part numbers and profile info in the FAQ.
Post by: RNandKT on July 02, 2015, 09:41:42 AM
The part numbers he lists don't seem to match any of the part numbers in the FAQ list, the specs he lists are the same as P4529656 except for the valve lift.
This is what he has listed
For sale. Mopar performance cam kit. Comes with mopar purple cam p# p4529314. Followers or lifters part# p4349147. Valve springs p# p4286813. Valve seals p# p4349121. Matched set.
Fits Chrysler dodge Plymouth mopar turbo 2.2 or 2.5
Specs. Lift 46 duration 240 overlap 24 centerline 108.
For me I would only change the CAM is I was getting some more Torque, HP is not really a concern, for these motors I would much rather improve the low end torque. The low Duration on this CAM and the higher lift, I would assume this CAM would favor torque, but my knowledge of CAM specs is somewhat limited. I am unable to find his part numbers listed anywhere else so I am not even 100% sure it is the correct cam for a Jeep 2.5
Post by: Jeffy on July 02, 2015, 02:23:56 PM
That's not a Jeep cam.  That's for a Dodge/Plymouth Omni/Horizon Turbo 2.2 and 2.5L.  Completely different engines.
Post by: sharpxmen on July 04, 2015, 03:32:53 AM
heads are the same, only difference the YJ head has a temp sensor towards the firewall on the driver's side, just leave the sensor in as a plug
Post by: Wrench on July 24, 2015, 10:50:54 PM
There are some differences in the 2.5 blocks, but those may just be differences between the XJ 2.5 and Wrangler engines.  My 1984 XJ 2.5 was a bit different than the '93 YJ 2.5.  Intake and exhaust patterns, engine mounts, and bellhousing are identical, though.
-'84-'85 use smaller diameter head bolts
-somewhere around 1990 the valve spring retainers shrunk in size, tapered (beehive) springs replaced the old straight ones, and the keepers went 3-groove instead of 1.
-the XJ timing cover has some small differences in bolt pattern where the alternator brackets mount.
-the XJ 2.5 crank is longer at the harmonic balancer, and belt alignment is about 1/4" further from the block than the YJ.
-the early years had a fuel pump mount/hole in the the block, the later years have this blocked out and it is just a coil mount.
-though the oil pans are identical, the later model oil pan gaskets are reusable rubber, and seal way better.
Post by: sharpxmen on September 29, 2015, 02:27:08 PM
this engine was revised in '86 prior to YJs being fitted with it, that is when I think most of the changes you mentioned occurred. heads are different prior to 91 if I recall correctly. For MPFI YJ era engines (91-95) there are no major differences compared to TJ I4 engines and major parts (not accessories) are in general interchangeable (some differences: oil pan drain plug position, extra temp sensor whole in the head, slightly different cam timing)
Post by: RNandKT on December 10, 2015, 10:03:54 AM
OK So resurrecting an old thread to get some input on CAM's again. Was trying to search but got a lot of info, but nothing exactly what I was looking for.
So I have finally gotten around to rebuild my 4 cyl. I cam across a place that I am buying my rebuild kit from and they will do CAM regrinding as well for only an extra $90. I figured choosing one of the purple cam specs would be the wiseest, but not sure which to choose. The 4 cyl will have the upgraded 4 hole injectors and the larger throttle body, and down the road when I need to replace the exhaust I will open it up a bit, but other than that stock. So I would like to pick CAM specs that will bump performace a little without needing to mess with the ECU at all. I would prefer to avoid replacing valve springs as well, but if there isn't a way around that it would't be a big deal.
So CAM experts which performance CA specs would you pick?
Post by: RNandKT on December 10, 2015, 10:12:25 AM
Basedd upon the research I have done I think this profile with the conical springs would be the best. The 4 hole injectors already make it run a little rich, so I think I would still be in the range the ECU could handle.
Factory Engineered Hydraulic Cam and Tappet Package for Mild Competition Application 256-256-40* Duration, .450" Valve Lift, 108* Centerline
Thoughts guys?
Post by: sharpxmen on December 21, 2015, 06:34:19 PM
110 centerline if possible, better torque if I'm not mistaking
Post by: RNandKT on December 27, 2015, 07:06:51 PM
So I believe centerline just pushes the torque curve up or down (I don't think it actually changes the amount of torque a motor makes, just what RPM it makes it, other than of course if you get outside the valve timing). Also a larger number  I believe would push the torque curve into the higher RPMs which I think would not be what you want for a Jeep. But again I am not an expert.
Post by: sharpxmen on December 28, 2015, 02:04:30 PM
you got it backwards, larger centerline lowers the rpm torque band, you're probably thinking of overlap
Post by: Wrench on December 29, 2015, 10:08:06 AM
Clay Smith Cams still lists the AMC 2.5 on their drop-down menu.  You select the cam grind, then pull down the options.
Post by: RNandKT on December 30, 2015, 08:28:55 AM
OK that explains why when Hesco used to make a performance CAM for the 2.5 they went to 110 centerline.
On Hesco's CAM they also went to 470 lift, but the guy who is doing the regrind was saying that the fuel injected motors can only handle so much before they start throwing codes. Even with the 450 lift you're supposed to richen the mix. Switching to the 4 nozzle injectors will help with that, and other people have done the 450 lift so I thin I am safe with that without causing problems. Hesitant to go to the 470.
As for the centerline. can that be changed on a regrind? Since the Hesco CAM was 470 lift and 110 centerline, would 450 lift and 110 centerline still be a good combo? Would be nice to favor torque. On the Hesco CAM it said it was requisite to change to taller springs, would the mopar conical springs be sufficient?
Post by: RNandKT on December 30, 2015, 08:37:50 AM
That explains the specs on the Hesco Cam
Advertised duration: 264        214@ .050
Lobe centers: 110 degrees
Lift: 470
They claim that is the best setup, and it is designed for the fuel injected motor, so maybe thats the best way to go. They also say:
This camshaft will require a spring and retainer change because of the increased lift. The valve spring seat will need to be machined in order to set up a taller installed height. Failing to do so will cause severe damage to the camshaft and related components. If the valve stems of your valves have triple grooves for the keepers they will need to be changed to the early single groove valves.
I wonder if the mopar conical springs will work? The most aggressive Purple CAM had 480 lift so I would assume the Conical springs since they work with that would be fine for the 470 on the hesco.
Post by: Wrench on December 31, 2015, 08:10:29 PM
Yes, the spring pockets should probably be machined deeper.  If I recall, the factory installed spring height is 1.6", which really limits your spring choice.  (I believe the most common Chevy size is 1.8") If you dont have the capability or knowledge to conquer getting the springs correct, take it to a really competent race engine builder/machinist and have them do it.  Getting springs or other hardware that cannot handle the lift you choose is a potential for complete disaster to your engine.  Lightening the valve train will allow for less spring tension required for the lift (ie: lighter valves, retainers, etc).  Just for reference, I had severe valve float issues on the stock cam/lift over 4500 rpm until I went to better springs.  I nearly dropped a valve because of it.
Incorporating lighter valves, beehive springs, and Ti retainers can go a long way in keeping your valves stable at RPM.  I havent looked into it, but I'll bet the LS stuff will fit our heads with a little work.
Post by: sharpxmen on January 01, 2016, 11:25:04 AM
you can also get longer valves or high length retainers and cup (although I'm not sure if they are available for the stock valve stem diameter), not necessarily need to machine the spring seat but would have to be tested to confirm the max valve travel. You can adjust the preload with spring shims afterwards. As far as I know the Hesco cam is good.
