General Forums => The Mess Hall => Topic started by: jakbob on April 08, 2006, 06:21:09 PM
Title: ENGINE BLOW!
Post by: jakbob on April 08, 2006, 06:21:09 PM
yeah so i blew my 4banger and wanted to know...can i just leave the transmission in as i take the motor out? or do i really have to take the transmission out?
Title: ENGINE BLOW!
Post by: Jeffy on April 08, 2006, 06:25:59 PM
Take the front grill out and leave the transmission in.
Title: ENGINE BLOW!
Post by: chardrc on April 23, 2006, 07:49:11 PM
why take grill out?.. on my 1990 yj we just took ht efan shroud off didconected wires ect and unbolted engin and lifter it out... i dont see why you would need to take the grill off.
Title: ENGINE BLOW!
Post by: Jeffy on April 23, 2006, 08:03:38 PM
Makes it easier to slip the engine in and out without having to lift it over the grill.  (might be working in a garage.) Although if he's taking the whole driveline out in one piece he'd need to.  It'll also gives you a bit more room to work with.  It doesn't take more then 5 minutes to remove once the radiator is drained.  Just a suggestion in any case.
Title: ENGINE BLOW!
Post by: wrangler387 on April 23, 2006, 09:38:56 PM
^ yea, lifting a motor out over the grill inside a garage i think would be impossible (i'm talking your typically 8-9ft ceiling or whatever it is) I know at my parents house I was inches away from the roof pulling the motors out of accords/civics/integras that were only inces off the ground.
To the maker of this thread... what is the damage report on the motor? is the head in good shape? I may buy it from you  :wink:
