General Forums => The Mess Hall => Topic started by: losduos on March 18, 2017, 01:23:10 PM
Hi, I'm new here and in the process of rebuilding my 2.5. Does somebody know the original cam specs? Considering getting one ground...
Thanks!
What year is your Jeep? YJ's and TJ's have different cam profiles.
Right, it's 95 YJ...
Valve Lift - 0.424"
Valve Overlap - 46*
Intake Duration - 270*
Exhaust Duration - 270*
Thanks, do you know the standardized values by any chance?
Comp is offering the following and I'd like to compare to stock:
200/206 @.050" .416"/.435" on 113 (to work with stock injection and springs)
I don't believe Comp Cams makes anything for the Jeep 2.5L.
Yeah, but they can grind you one. And that's what they came up with.
http://schneidercams.com/AMC_I4-hyd.aspx
Schneider also has some cam options. Pretty good prices as well. Just another option. They can also custom grind you one.
Joe
Hesco makes one as well.
http://www.hesco.us/products/7724/new-products/167924/rvob4-25l-camshaft
There's also the Mopar Performance Purple Cams which are defunct but you can someone to duplicate them. Straight from the FAQ - http://4bangerjp.com/forums/index.php/topic,4.0.html
Camshafts:
P4529656
Factory Engineered Hydraulic Cam and Tappet Package for Mild Competition Application 240-240-24* Duration, .430" Valve Lift, 108 Centerline
P4529657
Factory Engineered Hydraulic Cam and Tappet Package for Mild Competition Application 248-248-32* Duration, .440" Valve Lift, 108* Centerline
P4529658
Factory Engineered Hydraulic Cam and Tappet Package for Mild Competition Application 256-256-40* Duration, .450" Valve Lift, 108* Centerline
P4529659
Factory Engineered Hydraulic Cam and Tappet Package for Mild Competition Application 260-260-44* Duration, .460" Valve Lift, 108* Centerline
P4529660
Factory Engineered Hydraulic Cam and Tappet Package for Mild Competition Application 268-268-52* Duration, .480* Valve Lift, 108* Centerline
Thanks guys.
There is also 505 Performance offering 3 stages. Stage 1 is very close to stock I think, probably the most reliable one. Stage 2 looks also interesting but quite a bit more aggressive. Any advice?
http://www.shop.505performance.com/product.sc?productId=381&categoryId=40
http://www.shop.505performance.com/product.sc?productId=382&categoryId=40
The one Hesco used to sell was made by Clay Smith. they had 4 different grinds as I recall, I have the "RVOB" version Hesco sold.
