General Forums => The Mess Hall => Topic started by: moerl8088 on April 11, 2006, 08:35:31 PM
Title: Body lift fit?
Post by: moerl8088 on April 11, 2006, 08:35:31 PM
Ok, so I have a 3 inch body lift that I took off of my 2002 sport when I bought it.  On the local bullitan board a guy was looking for various means of lift for his 91 YJ.  I e-mailed him and he said that if i could find out if it would definetly work on a 91 he'd buy it.
conventional wisdom tells me it probably would, but not knowing the YJ at all, I can't say, so I thought I'd ask the brain-pile that is this message board.  All the kit really is is the spacers for each body mount, a corresponding body mount bolt, a bracket for the transfer case lever, a bracket to raise the steering column and a bracket to lower the radiator.  I'm guessing the transfer case lever bracket is useless because I thought YJ's used a straight stick instead of what my dad calls the "pistol grip" lever for the transfer case.
any thoughts?
Thanks in advance,
Luke
Post by: Jeffy on April 11, 2006, 09:53:26 PM
There are 11 body mounts on the YJ not including the grill supports.  I believe the difference is in the size of the mounts.  Although my JKS uses all the same size pucks.
TJ
(http://us.st11.yimg.com/store1.yimg.com/I/collinsbros_1889_15700646.jpg)
YJ
(http://us.st11.yimg.com/store1.yimg.com/I/collinsbros_1890_1588323.jpg)
Honestly, if it was me, I'd chop the mounts down to 1.5" or 1" in an band saw and sell off the other pucks.  You never know when you might want to use a slight body lift.
