General Forums => The Mess Hall => Topic started by: Ricou on May 22, 2006, 07:42:49 PM
About a year ago I had a tire rotation done. Afterwards I noticed that my front end had picked up a "shimmy" anytime I got to 50 mph, it would go away if I went above or below but would always show up right at 50. I’ve since rotated the tires a few times and it is still there.
Recently I threw on a 2.5" suspension lift and as cool as this is it has increased the "shimmy" to a full on "earthquake" that does not go away above 50 and I have to come to almost a complete stop to get rid of it. I have since had the alignment checked and adjusted but the "quake" is still there.
I am hoping that perhaps the wheels need balancing. Does anyone have any suggestions on any other possibilities as to what the problem could be...my dignity won’t let me take it to a dealership to ask.
If you've rotated the tires and the vibrations are still at the same wheel then I would check the wheel bearings.
Really does sound like a tow-in problem, I would have the alignment rechecked. Or just measure it yourself, it's easy to do. Here's a link, I'm too tired to type it all out. http://www.4x4xplor.com/alignment.html Also retorque everything under the jeep and check for bad bushings at the same time.
Not to sure about the wheel bearings being it. If it was doing it a year ago I would think the bearings wouldn't have lasted a lot longer. But if they're that bad it's easy to check just by raising the front wheels and feeling for play.
Now that you brought that up, it might be if you did not get an alignment after the lift. I had to go searching to see what kind of Jeep we're talking about. It's a TJ...
Hey everyone I’d like to introduce my self...I’m a freakin idiot. Might have been a good idea to mention it’s a '03 TJ in the beginning don’t cha think?
Thanks for pickin up my fumble Jeffy. :oops:
Does tj have a drag link, if it does check it for play.
I have seen a few people with Death Wobble on a TJ, and all one did was put a steering stabalizer on it. He has not had any trouble with it, and its almost been a yr now. Another buddy of mine Had Death Wobble, and the bushings in his control arms were worn out.
I have a YJ, and I got Crazy Death Wobble when I hit a bump or got going to fast, and I thought it was gonna shake my whole jeep apart before I came to a stop. Found out I had wornout bushings in my front spring packs.
May not cure your problem, but its worth looking at.
Do the TJ's have a Idler arm connected to the Drag link from the frame?
