General Forums => The Mess Hall => Topic started by: j-freak153 on July 02, 2006, 07:15:40 AM
anyone have experience wit this product...flips the d300 over so it can bolt up to yj axles...very cool concept...
Already swap transmissions? I don't think the D300 has a 21 spline input shaft available. Cost wise, it's expensive. If you've got a 23 spline output then you'd probably be better off considering a Ford D20 instead. Then used the money saved to buy lower gears or a twin stick.
