		General Forums => The Mess Hall => Topic started by: Elvin on July 14, 2005, 03:18:01 PM
				Hello Y'all
I just bought a 91 Jeep Wrangler (YJ) with a 3 inch lift. It's a 2.5 4 banger. I don't have alot of cash. Is there any simple mods I could make to increase highway performance
Thanks Guy's
Sincrely,
Elvin
				Do the 4.0L throttle body
				I looked up the prices for the throttle body. It sounds like a good Mod.
You said I should get a 4.0L Throttle body, but they sell one for a 2.5 also. Could you let me know what you mean exactly
				Check the How-To section here!  There's a post in there that explains how to get a stock 4.0L throttle body and put it in the 2.5L.  It's a $70 mod, and helps out quite a bit.
				Best Mod I did was to install 4.88 gears.
Ditto that...
				Gearing will make the biggest difference but that will depend on what size tires you currently have.  Manual or Auto.  The 4.0L TB will give you a bit more low end but everything works better when you have the correct gearing.
				4.0L throttle body and spacer, along with an airtube and conical K&N filter gave the best performance upgrade for me.  Follow it up with a better exhaust and an electric fan.  Then an ignition upgrade like Performance Distributor's FirePower kit.
As far as gearing, it's not the salvation you may think.  My modded 2.5L with 33" tires and 4.10 gears will keep up with my buddies stock 2.5L engine'd jeep on 34" tires with 4.88 gears.  Of course he needs to be geared a little lower but the stock axles won't allow it.
				I don't know how big of a tire you're running, but I have 31" tires and stock gearing.  Honestly, I think they are perfect for each other and the mods I have.  Nothing big: 4.0L TB, TBS, cat-back... and I still can still idle through anything in 4L.  In my opinion, I'm right where stock is as far as power to the wheels go and I feel pretty comfortable with it.  Keep in mind I only spent $300 to be where I'm at compared to whatever it would have cost to set new gears in (I got quoted $1200 back a few years ago for 4.88 and a TruTrac in the rear).
I bet your buddy does at Idle what takes you a bit of throttle to climb obstacles.
4.88 gears are bar none the best mod I've made to my jeep, besides the 8.8. Climbing a rock with a couple friends, I crawled up it effortlessly(With AT's i may add), a buddy with a 4L and 3.07's (And BFG MT's) needed a lot more skinny peddle then me.
PS where did 5'th go for you :)
				I have done them all like 4.0 throttle body, throttle body spacer, K&N intake. MSD coil & wires Pacesetter header, high flow cat and Kat back. I also have 4.88 gears and 31" tires. The gears by far were the best money spent. I now have 5th gear again. I bought my gears and had them install for under $700. I can take my jeep up to 75MPH with no problems. A little scary but I can if I want. My next upgrade is an adjustable crank shaft sensor for a little more timing and an electric fan. I don't think there is much more I can do to my little 4 banger. I also tow my Ski boat with it. It does good doing it but doesn't stop to good. It likes to push the YJ around a bit.
				if you're not going to do gears, I think you'll notice the biggest improvement from the electric fan.  I'm installing mine now.  The stock fan weighs 5lbs (checked it myself), just imagine how much HP you're using to spin that thing around.
				Sorry didn't know you had 4.88's  :D
I bet I can get up to 75Mph as well....... but i wouldn't attempt it, a jeep is scary enough at 60!!
I agree with the Fan thing, I've heard its a really good mod. Another option, if your a backyard builder, is to buy another used 2.5, and mod it, like do your own porting and polishing, add a performance cam, and oversized pistons and the like, do it on your own time, at a leisurly pace, that way when your 2.5 throwns the bucket, you've got one ready to go in her with a lot more power. Repeate the process on the blown 2.5 and your set.
Hmm, I've taken my Jeep up to 80mph.  It only gets scary if you keep your eye's open. :wink:
				Having had 33's for a while (still stock, engine to axles...) I'd tend to forget how far off my speedo and odo were off...  On a recent long drive to Missouri, I clocked 80mph on my GPS.  Flat ground, little wind, and loaded with military gear and my mountain bike.
I was very impressed with that entire trip...I had just installed power steering (my manual box was shot) three days prior so I had another thing robbing power. Still averaged over 185 miles per tank (also per the GPS).  Still no 5th.... :?  Nice crack in the exaust manifold, catalytic is beyond the grave, and I have a hole in the muffler.  Guess that opens her up a little....
8.8 with 4.88 is in the works though....and the fan....and....and....and.....
				I can still occasionally use 5th, and can comfortable cruise at 75 or 80 with my stock 4.11 gears and 33" tires.  Dont' get me wrong, regearing is good and I'll be at 5.38's one of these days, but the power mods have been an inexpensive temporary solution as regearing is cost prohibitive for many.
				Have to agree. Re-gearing is out of the question right now until someone can help me do it. I refuse to pay someone to do it.  I want to know how to do it myself anyways. I know how to take the rear end apart etc.. I just don't know how to shim it correctly. Sounds like a small issue but I figure someone knows how to do it and can show me when i get ready to do it.
Until then the 4.0Tb, inertia ring, and TBSpacer will have to do. They actually do pretty good. i use 5th gear every now and then on the highway with 33's but usually 4th gear works great. I can cruise at 70mph at 2700 rpms and can hit 75+ at 3k+ rpm's.
I like it but will eventually go to 4.88's
				sheesh i run 35 ssr swampers  and 4.10 gears  my only salvation is the tera-low offroad but on road its a super turd.... the 4.0 tb sounds good any thing to bump it up a little  and yes this is my daily driver
Yea, if you haven't already done the 4.0 TB, I would definately find you one and bolt it up. It's definately worth the money spent.
Just remeber to swap both sensors from the 2.5L TB to the 4.0TB.
The 4.0TB sensors will make your idle shoot way up.
