General Forums => The Mess Hall => Topic started by: Liljeepz on September 21, 2006, 04:47:22 PM
Title: Fan control
Post by: Liljeepz on September 21, 2006, 04:47:22 PM
during the summer I was driving with my AC on and the fan setting 1 stopped working.... No biggie I turned it to #2 setting, That worked for about a week then that one went out.... so I would use setting 3.... That one went out a few days later. It cooled off and I don't use my AC any more, but now that its getting colder in the very early morning I turned on my heat and it reminded me its full blast fan or nothing, I know its a matter of time before that goes out and I have no heat, I would like to get it fixed this weekend. Any one know what this could be? I Think it could be the fan knob/switch it self that has gone bad.... but I have no idea how it works, I never pulled the dash apart yet. Any ideas?
Title: Fan control
Post by: dexetr30 on September 21, 2006, 06:15:48 PM
Yup, I've got the same troubles. Only my two lowest settings are not working. Any suggestions?
Title: Fan control
Post by: chardrc on September 21, 2006, 07:41:18 PM
i have 2 ideas.. one it could be the switch. or 2 it could be a relay/ relays going bad or maybe bad conections.. we had a relay go bad on our s10 so we didnt have high for our fan and we jsut needed a new relay.. but more than 1 goign bad sounds fishy :fish:
Title: Fan control
Post by: Liljeepz on September 22, 2006, 03:28:02 PM
I think I will just replace the switch first. Any ideas where to get something like that other than the stealership?
Title: Fan control
Post by: dexetr30 on September 24, 2006, 07:47:08 AM
Try the local scrap yard first. Mine was a relay. I went to the yard and paid the guy .50 for it.  8)
Title: Fan control
Post by: Jeffy on September 24, 2006, 02:52:06 PM
Those dial switches sure don't seem to last.
Title: Fan control
Post by: Liljeepz on September 24, 2006, 05:33:58 PM
I got this reply on my club forums.
Quote
Its very common on any vehicle.... the resistor block burnt out. The high speed will always be there unless the blower (fan) motor takes a crap. The resistor block is not used on high. the resistor block works by reducing the amount of voltage to the blower (fan) motor, depending on speed low, med. ON high speed battery voltage (12v) is aplied to motor. When the voltage is being reduce by the block, it builds alot of heat eventually the heat melts one or more of the circuits.. causing one or more speeds to be lost. Any auto parts store should have them. ( or just go to jeep) I work at a shop and get discount on parts. Pm me if u need help geeting it...
Title: Fan control
Post by: dexetr30 on September 24, 2006, 06:00:05 PM
Quote
I had this same problem with a 2000 grand am se. Actually, that was one of many problems with this car that I had. So... I traded it for the current Jeep.
Title: Fan control
Post by: Liljeepz on September 26, 2006, 06:50:49 PM
Just an update, This was the problem!
That guy got me the part and I installed it today...
Problem fixed! I don't know how much the part cost, he got me a cut rate at $13.
