General Forums => The Mess Hall => Topic started by: SDentone on October 11, 2006, 04:17:43 PM
Title: What is the best way to get more Top End?
Post by: SDentone on October 11, 2006, 04:17:43 PM
1990 YJ 2.5L 120,000 miles on the engine.  What can I do to get more power for climbing hills on the street with out loosing the torque needed for off road?  Be gentile I am a newbie with Jeeps and DIY projects.
My first though was to change some body parts for Fiberglass parts.
1990 Stock YJ No upgrades on this thing......YET.
Title: Re: What is the best way to get more Top End?
Post by: Jeffy on October 11, 2006, 05:34:39 PM
Quote from: "SDentone"
Well, I'd consider the TCG 9lbs inertia ring.  It will add more mass to flywheel which will help keep it's RPM's more constant when going up hills and what not.  It won't increase the top end though.
Actually, there isn't much on the top end.  I rev up over 4000rpm's so I can keep the RPM's high when I'm forced to downshift.  The mods I've got on my Jeep make the engine run relitively smooth at higher RPM's which is really nice.  It used to make a lot of noise and had a vibration at higher RPM's which was a bit annoying.
Still gears are your friend.  Gearing lower will make a huge difference.
Post by: chardrc on October 11, 2006, 06:43:47 PM
i read all this talk about pushing the 4banger over 4 grand.. but when i drive my jeep i can never getmusellf to go over 4 grand.. i feel like im pushing it to much and its going to blow.... and when i push it up to 4 grand i get a burning oil smeel afterwords :roll: ..... on top of that my motor is in need of a rebuild...
Post by: SDentone on October 11, 2006, 07:03:33 PM
OK TCG is?... Again please forgive my ignorance.  I have talked to alot of people about engines and such but I have never walked the walk so to speak.
Post by: Jeffy on October 11, 2006, 07:13:41 PM
Sorry about that.  Tri-County Gear.  They sell a 9lbs inertia ring for around $150.  It involves taking the transmission down so you might not want to do this unless you're going to replace the clutch since the tranny will have to come out anyway.
I still haven't done this but it's one of the things I'll consider when I have to do a clutch.
As for not being able to rev to 4000rpm.  You're just not trying.  There is no reason you shouldn't be able to rev the engine to the limiter.  Although on a older/higher mileage engiine you might not want to rev it as high for fear of breaking a rod or springing a leak in the headgasket.
Post by: chrisfranklin on October 11, 2006, 08:34:11 PM
Best way to get more top end?
Swap in a late-model Ferrari 12 cylinder.   After that, your top end problems will be over.
Post by: superman1456 on October 11, 2006, 09:15:23 PM
go with a 4.0 if your goin to rebuild keep the 2.5 logo on the jeep and you will be happy with it been there done that it works out well
Post by: Bounty Hunter on October 11, 2006, 10:46:05 PM
Swap in one of these, 4banger from the Honda S2000 redlines around 11K.
(http://www.mcdonaldindustries.com/james/Torik/P7300006s.jpg)
Consider regearing for optimal power range while on the highway, generally means lower gears with the 2.5L engine.  Also check out a perfomance cam to bump power up on the top end, install new valve springs for the added lift, and a double-roller timing chain.  Header would help as well.
I don't think the inertia ring will do a thing for top end, it'll have the same effect as adding heavier tires, robbing power and slowing the engine.  I think the only place the inertia ring helps is when bouncing off idle while wheelin, keeping the engines momentum between power strokes.
Post by: Jeffy on October 11, 2006, 11:09:12 PM
Quote from: "Bounty Hunter"
Actually it won't slow the engine.  Typically what happens when you install one, the engien will not drop RPM's as fast as it used to and you end up chirping the tires till you get used to it.  Onroad, it's not that noticable other then keeping the RPM's steady.  Like I said, this will help a bit when trying to maintain RPM's on the highway a bit.  It's different then adding larger tires, since the weight is not on the engine itself.  But like you said, it will help keep the engine from dying when idling very low while in gear.
Post by: Bounty Hunter on October 11, 2006, 11:18:01 PM
Seems to me that it's more power robbing weight on an already anemic engine.  And I compared it to heavier tires, not larger, to keep things in perspective.  I only see the benefits off idle, but I've never ran one either.
Post by: Jeffy on October 11, 2006, 11:50:16 PM
Well, they do take up some of the off the line power but once you're going you won't notice it as much.  Like I said, it will help keep from losing RPM's as fast when at speed but it's no replacement for more overall power.   A friend of mine runs one with his 2.5L in downtown SF and has no complaints.  There should be a few others here who have them.  But we're really straying now.
Go with gears like we both stated, SDentone.  It will make the biggest difference and you'll be happy...until you go with larger tires.  :lol1:
Post by: SDentone on October 12, 2006, 08:42:19 AM
OK Maybe I was a little vague on the question.  So let me restate...  I want to climb mountain passes without dropping to 35 MPH and not loose low-end power for off road.  Am I asking too much out of this engine?  Also I was thinking a little subtler than a Ferrari engine replacement. (Funny)  Would making the body lighter help?  Would adding a good after market header, and high flow CAT help?  Maybe a new air filter.  Is there a good tune up kit out there?  I use this Jeep to drive to work and off road so it has to be more practical for now.  Maybe next year I will lift it 8" and put 33s on it and bla bla bla....
Post by: Mozman68 on October 12, 2006, 09:17:37 AM
re-gear to 4.88's...or lower if you have D44's or the like.
Post by: Bounty Hunter on October 12, 2006, 09:29:37 AM
Sounds like you're running stock size tires, so you don't want to regear too deep or highway performance will suffer, rpms will be way too high.
You can add things like a cat-back exhaust, 4.0L throttle body and spacer, airtube and conical filter, electric fan, etc.  You can even go as far as adding a performance camshaft.  All told I think you're expecting too much from the 2.5L and the aerodynamics of your rolling brick.  (think supercharger).
My 2.5L has most of the above mentioned mods (short of a blower) and it does fairly well on the hills.  I'm running 32" tires and can hold some pretty good grades at 50 or 60mph with stock 4.11 axle gears.
Post by: SDentone on October 12, 2006, 10:49:10 AM
Thanks for the info.  Yes I am running 100% stock for now.  The clutch was replaced at 80,000 and the Head gasget at 100,00 or so.  I am not expecting to do 70 through a mountain pass but 50 0r 55 would be nice.  The pass I go through is 5 lanes wide anyway.  I can hang in the slow lane.  So what kind of performance changes can I expect with a new cat and exhaust, Air filter system and Throttle body?
Post by: Jeffy on October 12, 2006, 10:49:18 AM
What size tires are on it now?
The problem with a Supercharger is that his Jeep is a 90, the only kit out there is the avenger and that's for a MPFI.  Although there was a company who was installing centrifugal SC's on Jeeps and other cars.  I still can't remember the name of the shop though.  You could probably make a custom setup though.
Post by: YJmechanic on October 12, 2006, 03:48:24 PM
if you are still stock then you should see good gains from small mods.  i thought on 31 my ram air intake made my jeep insane.  everything listed will help especially on the top end and if you stay stock they should net you good gain.
i run my motor at  7k rpm when really running it but then again my engine was built for high rpms.  and the idea of swapping to a 4.0 is just giving up and also i built my motor for half what the 4.0 conversion would have costed and i have more power than any 4.0 with my setup i have ever met.
Post by: jwrape on October 12, 2006, 03:50:09 PM
I have a inertia ring on my flywheel since I did the AX15 conversion when I bought it back about a year or more ago. I LOVE it. I can bog my motor down to 300 rpms and recover it. It doesn't stall NEARLY as bad as other 4 banger I have seen and I don't ever chirp the tires when down shifting. My mileage is still 14 mpg which is what it has always been. I think it is a must do if you are replacing the clutch or doing tranny work.
My Dad has one too. My motor has over 200k on it, not sure exactly how much over and I can still get to 90mph down hill, 85 on level ground.
I am riding on 33x12.50's 4:10 gears
Post by: superman1456 on October 12, 2006, 08:57:49 PM
YJmechanic what is your setup i have a custom built 4.0 and its an anmial. cant keep the wheels from spining no matter what i do. besids the point what is your setup in detail?
Post by: YJmechanic on October 13, 2006, 05:12:42 AM
there is an entire writeup on my motor if you look for it.  my point is not that a 4.0 cannot be more power than my motor i said my motor cost half as much to build as the conversion and it has more power than any of the 4.0 i have seen.  that is not to say there aren't 4.0 out there woth more power just that it would cost a lot more to build because you have the motor and conversion costs and then building and tuning that motor.  it's just not cost effective and sorry but just swapping to a bigger motor is no fun for me.  anything can be done with almost any motor if you want to.  i have a subaru with more power coming out of 4cyl than both our motors put together.
Post by: wrangler387 on October 13, 2006, 05:45:54 PM
getting the ring definately won't help with anything other then off idle. Besides that it will just hurt you, going lighter will help cruising, but will hurt your off idle. Also s2000 motors don't rev to 11k stock, especially not the newer versions, they are amazingly efficient motors though... keke bigger stroke then the jeep too i believe, i still dont understand why the 2.5L has such as small stroke.
Post by: Bounty Hunter on October 14, 2006, 06:01:40 AM
Quote from: "wrangler387"
That was the number I remember from when they were first released on the market.  The current version is 8200 compared to the 2003 model's 9000 limit.  Still up there for an automotive 4banger.
Post by: jwrape on October 14, 2006, 08:05:15 AM
I really didn't notice any other losses. Like I said I can get up to 90 and pretty much hold around 70-85 or so on flat ground, but then I do have a electric fan, 4.0 tb and a K&N so those prolly help to. I would really do good if I had 4:88gears.
Post by: wrangler387 on October 14, 2006, 07:26:54 PM
They stepped up the stroke on the new motors, they now mimic the old H22XX motors. Bigger stroke then our 2.5L motors. Most honda motors rev pretty high, they are efficient motors, especially the newer K-series motors. 200whp all motor is easy.
The rings may not affect highway that much, but they definately don't help. I know every car i've put a lighter or lightened flywheel into was a noticeable difference in acceleration, but the more RPMs you have to give on a launch though since the motor has less inertia to initiall get the drivetrain moving.
Title: I now have a plan.
Post by: SDentone on October 19, 2006, 11:40:39 AM
First I am rounding up a reasonably priced high flow CAT and Cat back exhaust.  Then new cold air induction system.  Then 8mm wires and a super coil, and spark pugs gapped to .065.  Thanks for all the info. I appreciate the help for the newbie.
Oh, and Nice new Avatar Jeffy.
