General Forums => The Mess Hall => Topic started by: tanbuffsidriva on October 18, 2006, 02:03:56 PM
ive got the 100w set of kc hilites . for anybody whos installed these, where did you mount your switch? just looking for some ideas. the install seems like it should be pretty easy
I am only using 2 of the 3 spaces I have for switches on my TJ (rear wiper and rear defrost). I just took the assembly out and drilled a hole in the blank one in position 3 for the hi-lites. Had a hard time getting the wiring to reach that far though...across tot he battery...across the front to the firewall hole...back across to the middle for the switch.
Mine began life as a hardtop, so I took out the factoty swtch panel and milled myself a new one.
(http://i68.photobucket.com/albums/i33/jlafaive/DSC00531.jpg)
i first installed a double tuffy overhead for my CB and deck......i took out the old radio...installed a 16gage steel panel where that would go and hooked up my KCs switchs....with the other lights installed,,,,(rock lights and hellas) i really made a good look for everything and my Deck wont be a out in the open :D :D
