General Forums => The Mess Hall => Topic started by: GlacierJim on December 19, 2006, 10:28:30 PM
Looking at buying a motor with the miles unknown. They have run a compression check on it and I was told the following:
"MOTOR WITH 140-150 ON THE COMPRESSION, 25 PSI ON THE OIL PRESSER"
Can someone give me a link to show on a graph where this motor stands? Or give me some idea of what the normal compression range is @ with 25psi of oil presser?
This is for a 1995 YJ 2.5L
Thanks,
Jim
Well, that's pretty good compression. Although I'd like to see each cylinder listed instead of a range. If one's 140 and all the others are 150, I'd be wondering why it's lower. Although it's got good compression. Jeep recommends 120-150 as good. Max variation is 30psi.
I'm not sure what's the deal with the oil pressure. If they're doing a cylinder leak test they should be using around 80psi to replicate the engine's normal pressure. For a compression test, I've never pumped up the oil pressure. Although I was doing compression tests around 15 years ago.
Jeffy,
Once again you have the answers :)
Thanks and wish you happy holidays!!
Jim
It'll only take you a little while to check it yourself though.
