General Forums => The Mess Hall => Topic started by: Dan Marino on January 30, 2007, 05:46:56 AM
Title: Doors Won't Unlock
Post by: Dan Marino on January 30, 2007, 05:46:56 AM
Hey Folks,
I'm having difficulty unlocking my full steel doors with the key.  We've had a recent bout of cold weather here and I washed my Jeep over the weekend.  Now yesterday and this morning the doors do not unlock using the key from the outside.  What do I need to do to fix this?  I'm guessing I need to pop the inside door panel off and lubricate some mechanism?
Thanks,
13
(By the way I hate Joe Montana.  That guy kicked my butt in the Super Bowl)
Post by: Jesse-James on January 30, 2007, 06:11:37 AM
One you get the panel off, it will be apparent what needs some juice. Stay away from WD-40 or eqivelant because it evaporates fairly quickly. I like white lithium grease, but as long as it gets the job done use whatever.
Post by: Jeffy on January 30, 2007, 12:09:35 PM
Take the card/panel off the door.  There is a metal panel by the striker and has some screws.  Take those off and it should expose the innards of the door.  You might need to adjust the rod a bit.  I know the arm on the lock itself has some play to it also.
My driver door likes to lock my out when it gets cold too!
Post by: lanulos89 on January 30, 2007, 01:27:39 PM
same i just saturated it with wd 40 tho oh well seems to be working
Post by: Jeffy on January 30, 2007, 02:20:09 PM
Quote from: "lanulos89"
WD40 works but it doesn't work forever.  WD stands for Water Displacement.  It's not really designed to be a long term lubricant.  Although some CLP Break Free would work.
Title: Re: Doors Won't Unlock
Post by: jeepheap on March 08, 2007, 10:54:53 AM
this is an old thread but wanted to put my 2 cents in.... DON'T ever put graphite in any lock or locking set that is going to be out in the weather. graphite is a metal shaving that can and will rust. and if you put a whole lot in a little space that gets moisture.... well dont say i dint tell you.
the only thing i learned in the two weeks i worked with a lock smith in high school. well that and how to drill out a lock right. hehe
Post by: GreenBayjeeper on March 08, 2007, 10:38:46 PM
Knowing that this is old, I too wanted to add my $0.02 worth.
My locks froze up after washing the other month... Probably when this was new...  And I just put the key in with the door in and pulled the handle from the inside a bunch off times, while trying the key and outside handle.  Eventually it loosened up, and has been "not sticky" since then.
Not scientific, but it worked.
Post by: Steve-0 on October 09, 2009, 12:43:04 AM
I will take a stab at this old post. I opened up my door panel and found that the arm from the lock mechanism that has the plastic rod holder isnt being turned enough by the lock. I can lock and unlock it fine from the cab, but the outside lock mechanism is no good. How do I take the ting out and get another one? Or even just swap the rear door one with this one?
Post by: neale_rs on October 09, 2009, 07:26:11 AM
Take a looks at this:
http://4bangerjp.com/forums/index.php/topic,5811.0.html
Post by: Steve-0 on October 12, 2009, 09:51:07 AM
This was a great work-up! It worked like a charm. I took the c-clip out, popped the lock out and removed the e-clip and the z bracket that has the plastic retainer for that z bar. Took a square chunk of plastic from an empty box from some bolts I bought from the store (perfect thickness) punched a hole in the middle (big enough to go around the biggest diameter and that is just below where the e-clip sits), rounded the edges, put that plast ic piece inbetween the z bracket and the e-clip and put it all back together. Works great. Thanks.
Post by: Jeffy on October 12, 2009, 12:18:57 PM
Glad it worked.  You're the first person to do it, I think.
