General Forums => The Mess Hall => Topic started by: rwing1 on February 13, 2007, 08:50:17 AM
Title: Shackle dimensions for YJ
Post by: rwing1 on February 13, 2007, 08:50:17 AM
OK I have a front shackle that has apparently been bent recently.  I need to have a set made up frt/rr but am not sure what size to go to.  The factory stampings are puny compared to anything in the aftermarket.....  should i go 1/4" or 3/8" thick steel stock? and should I go with 1.5" or 2" wide? And then what length?  I have stock springs and would like to gain a bit if I am putting new shackles in anyways....... stock is about 4" hole-to-hole I think, so would stretching that to 6" for about an inch net lift be too much?  I don't want to loose too much Caster angle in front. And I was thinking about welding and/or bolting a brace for an "H" style for better road manners around corners,  currently I have a drivers side shackle/spring eye leaning to the left and I suspect it's moving to some extent when driving around. As always I need to do this myself to save some non-existent money. I Really appreciate the opinions of the more experienced guys than me  on the forum! :bow:
Title: Re: Shackle dimensions for YJ
Post by: Jeffy on February 13, 2007, 11:08:43 AM
Most shackles use two plates so width does not matter at all.  Only some aftermarket shackles use the H design. H design is used to stiffen the taller shackles BUT does hinder movement.  If you're going to stick with stock height then get some  3/8's punch two holes and you're done.  Stock leaf width is 2.5".  Stock length is 4".  Keep in mind for every increase in length, you only make half that in height.  Also keep in mind that 1.25" Lift (7" Total) is the MAX and you probably shouldn't go near that with stock leafs.  3/8" lift or .5" lift would be ok if you want a bit more though.
My front shackles are custom made from 3/8" stock punched out on an iron worker, I believe.  Pretty simple.
Post by: rwing1 on February 13, 2007, 12:02:37 PM
Thanks Jeffy! I picked up some 2"x 3/8" flat stock cut to 8" lengths at lunch today. I might drill 3 holes in each so I can have a choice of either 6" or 5" center-to-center hole spacing for either 1/2" or 1" lift. Just holding the pieces up against stock shackles looks as though they will be a great improvement in strength. So far net cost is $10 for all four corners :clap:  I don't have the Jeep with me today.....what size are the bolts I need to pick up on the way home? 1/2"x4.5" big enough to leave threads the other side of the nuts?
Post by: Jeffy on February 13, 2007, 12:13:25 PM
Ok, I went out and check the bolts.  They're 1/2".  I didn't bother measuring the length since it's a bit cold outside.  :uhoh:
make sure you cut off any excess shackle so you're not dragging them if you use the .5".
